1 - 6 of 6 Posts
Hey guys.
I have the following issue. I drive a BMW E60 M5 2007 with around 65 000 km (around 40 000 miles).
For the past few days it has been major cold -10 degrees (14 F). I live in Vienna, Austria.
In the morning I started my car, and when engaged R and then D, I get the red cog of death with Transmission fault. This cog and information screen disappeared after around 4 seconds.
I thought to myself, probably because of the cold the oil is a bit frozen or what ever the reason.
Later on, it was doing this everytime I started the car. I called up BMW in Vienna and made an appoint for just a trouble code read-out why I am getting this.
I went to the dealer, they told me first they are going to read out all the codes from the SMG and in 1 hour I should come back. I came back, and they are telling me that the hydraulic oil level was a bit too low, and they refilled it. After the refilling their computer diagnosed that everything is fine.
BUT, whenever they start the car, put the car into D or R, it makes a major jolt and the engine stalls.
I asked them what the **** they just did to the car. This problem never happened to me.
They told me, nothing, they just refilled the level and from then on the car became not driveable.
They are currently in connection with BMW M Germany and trying to solve the problem.
My question is the following. What the hell did they do to my car? Did anyone have these problems?
Is it maybe just the hood sensors? But if it would be, Neutral would start blinking and the information screen would come up.
I am getting paranoid and do not know what to do.
And the dealer is probably counting up every hour they lay their hands on the car.
PLEASE HELP!!
Regards from Austria.
Super Moderator
At least be happy that it happened whilst in their "care and control." Imagine if you had driven for a few days then discovered the new problem. They probably would have plead ignorance and shifted blame to you.
I would not take possession of your car from them until they remedy the situation they exacerbated -- instead of fixed.
I think it is too early to assume and/or conclude the "dealer destroyed you car".
I think you're being a bit presumptuous. SMG isn't a bullet proof system and is prone to issues. Wait and see how things pan out and give the dealer the benefit of the doubt. Working with the dealer and being cordial with them will go a long way than having a negative attitude against them. That will only be counter-productive.
In the end, just make sure you make an account of everything that is done, or not done, and document things. If the dealer is indeed taking you for a ride, you'll know soon enough.
If your car is out of warranty, repairing it will be costly so you can expect a high repair bill.
I had this problem a few weeks back. Dealer claimed it was due to low battery voltage
1 - 6 of 6 Posts
