1 - 1 of 1 Posts
Just in case anyone out there has an F30 3 Series car and might be interested in these. I have a brand new set of DINAN Wheels. These are original DINAN Wheels, not replicas. These wheels used to cost $2299 - $2500 per set. They are no longer available from DINAN. These are NOT staggered wheels, they are all the same size.
They are brand new in boxes. These wheels may work on different models, depending on the hub size and offset. Please do your research for fitment.
These particular wheels will fit BMW F30 (3-Series) models from 2011 - 2019. They were recently installed on a 2016 BMW 328i that is lowered on DINAN Springs / Suspension. They are a direct fit and bolt right on. Car in the picture is fitted with 245/30Z/20 Size tires on all four corners. You might be able to larger on the rear tires.
Here is some information from DINAN:
Dinan has utilized its extensive knowledge of BMW specifications to produce premier cast aluminum wheels. Dinan wheels are well regarded within the industry as some of the most aggressively wide based options available. We do this to provide the car superior traction and versatility under a myriad of driving conditions. In addition to affording the car the ability to attain and hold peak performance ratings as required by Dinan's lofty standards the Dinan branded wheels deliver a unique design that augments the refined sophistication inherent in all BMW vehicles.
Dinan Wheel Highlights:
• Lightweight Aluminum One Piece Cast Wheels
• High performance aluminum for high strength-to-weight ratio
• OE TPMS and lug hardware compatible for ease of installation
• Utilizes BMW alignment system for easy fitting and alignment
• TUV, JWL, and DOT approved
• Weight optimized by FEA analysis
• DINAN center cap included
Color: Black
Offset: 44mm
Hub: 72.56
Bolt Pattern: 5 x 120
Weight: 27 lbs
Suggested Tire Size: 245/30/20
Worth 3 DINAN Points.
Please send a note if you're interested or have further questions. Pick up is preferred please.
The Price is of $850 for the complete set of Four Wheels.
Thanks for looking.
939071
939072
939073
939074
1 - 1 of 1 Posts
