1 - 1 of 1 Posts
This might be more for the F10 Owners. That was the last car a similar set of these wheels was installed on and worked out great.
I have a set of DINAN Cast wheels. These wheels are no longer available from DINAN. A set was installed on a 2014 BMW ///M5. The wheels are brand new, still in their boxes and are Silver in colour.
Here are the specs:
Size: 20 x 10
Offset: ET47mm
Bolt Pattern: 5 x 120
Hub Bore: 72.56
They are a squared set and they were mounted on the 2014 M5 using 15mm Spacers front and rear. Rear spacers were used just to give the car more aggressive stance, otherwise they bolt right on.
As mentioned before, these wheels are brand new, they have never had tires mounted or ever been mounted on a car. They DO NOT come with tires. You will need tires and also TPMS sensors if your car has that feature.
It is my understanding these wheels will work on other models also, depending on the hub size and offset. You can also use spacers to make them fit. Please check and confirm fitment for your individual car. They were also installed on an F10 535i as well, but those were a staggered set.
Here is information from DINAN:
Dinan has utilized its extensive knowledge of BMW specifications to produce premier cast aluminum wheels. Dinan wheels are well regarded within the industry as some of the most aggressively wide based options available. We do this to provide the car superior traction and versatility under a myriad of driving conditions. In addition to affording the car the ability to attain and hold peak performance ratings as required by Dinan's lofty standards the Dinan branded wheels deliver a unique design that augments the refined sophistication inherent in all BMW vehicles.
$1650. Will consider shipping at Buyer's expense. They cost about $200 FedEx Ground for the set.
936848
936849
936850
936851
1 - 1 of 1 Posts
