1 - 6 of 6 Posts
I have installed the kit from www.bimmernav.com and I am unable to pair it. Has anyone else had this problem? The display says bluetooth pairing, but it never is able to get to the point of putting the passcode.
'01 /// Imola Red
Which phone are you using?? Are you sure your phone is in discoverable mode?? Make sure the phone and the antennae are near each other.
I am using a Motorola V600 and I have gone through all of the steps. It tries to find it for 60 seconds then gives up. I even held it right next to the antenna and tried.
You might wanna try a hard reboot. Disconnect the battery cables and then short the positive and negative cables together, get in the car and turn the key to the on position so you can drain out any remaining power left in the computer system. Wait a few minutes and connect the battery again and try it then.
Glad it all worked out. I think Bimmernav has a bluetoooth and voice recognition manual on line. You can print it out and learn all the cool little tricks.
1 - 6 of 6 Posts
