1 - 20 of 20 Posts
Bimmer Retrofit is proud to announce that the NBT Retrofit kits for E-series (E6x, E7x, E9x, E8x) are available!
Since we first launched this retrofit in January this year, we've fixed some bugs along the way, and now all features are supported.
You will have an opportunity to purchase either the complete NBT retrofit for E6x or just one of our eNBT Retrofit Adapters if you are planning to source your own hardware.
The complete NBT retrofit for E6x will include:
  • NBT head unit, updated with the latest software
  • NBT CID display for E9x/E6x
  • eNBT PNP adapter
  • ...as well as any other parts that may be required in your case.
Please check out our videos for demonstration of the NBT retrofit using our own eNBT Retrofit Adapter.
NBT Retrofit kit in E92:
NBT Retrofit kit in E71:
Sports Display:
Other screenshots:
Videos will be coming soon
Stay tuned and let us know if you have any questions! ;)
Sports Display - Power and Torque
We are constantly improving all of our products, and we are proud to share with you two of our latest improvements for the Easy (eNBT) Retrofit Adapter.
1. Now all of the NBT head units are supported. This means that HW21 is no longer an issue! YES, HW21 is now supported and navigation will work perfectly fine in your E-series BMW with NBT powered by our eNBT Retrofit Adapter!
2. Our eNBT Retrofit Adapter now supports the Sports Display for NBT head unit in E-series! You can have Power and Torque displayed on the screen, just like it appears in F-series! It will show you real-time Torque and Power values of your engine.
Thank you for all your emails! We are replying to all email within 24hrs. If you do not get a reply within 48hrs, please try to contacting us again using a different email address, unfortunately some of your emails are blocked :confused2​
eNBT Coding Utility
eNBT Coding Utility
In the near future all of our eNBT Retrofit Adapters will come with a eNBT Coding Utility*.
The utility is already available for download free of charge (from our online store) and it will let you code required NBT settings for proper operation in E-series vehicles.
No special coding knowledge will be required for this: you will be able to select the desired options on your computer screen, and by doing so, will be able to correctly code the NBT to work in E-series.
* This eNBT Coding Utility is compatible with all of our eNBT Retrofit Adapters purchased from or from one of our resellers!
Nbt hw 21
NBT HW 21​
One of the questions that we get a lot is whether NBT HW21 is supported. The answer is 'YES', NBT HW 21 is supported, so you do not need to worry about navigation not working if you are installing NBT HW 21 in your E-series.
Any one of our eNBT Retrofit Adapters will support your HW21.
We also offer COMPLETE NBT Retrofit Kits for E6x vehicles. Please contact us for pricing information: [email protected].
As a reminder, when you contact us for a quote, please indicate your vehicle's VIN - the VIN of your vehicle is required, since the price of the NBT kit depends on your vehicle's configuration.
have purchased this NBT kit ( and rear camera ) from Bimmer retrofit for my May 2007 production LCI E60 M5 SMG on Aug 18th, and received the kit on Sep 26th. will update this forum as the installation progress.
What did it cost you?
I got the cic retrofit off them a little while ago. Works a treat. Just wondering how much more the CIC is over the new NBT is
The price of NBT kit is VIN-dependent, i.e. price of the NBT kit depends on the configuration of the vehicle. For a quote, please send an email to [email protected] and include your vehicle's VIN. Also, a sale is coming up - so special pricing is now available for a limited time only!
We did numerous retrofits for their customers, including NBTs. Mainly navigation in HUD in E-series with NBT never worked, all other functionality was intact. You may need to verify your installation :cheers:
dear Vinzer and hi,
tks for your response and interests to the posts re our NBT retrofit from bimmer retrofit.
pls note we have confirmed email that they had NOT test / validate those original functionality re E60 M5,
- ie wrong mDrive,
- missing climate control,
- no settings / display of heated seats,
- no settings / display of active seats,
- missing head up display setting,
- and more
if you had a previous specific experience retrofitting NBT system to an E60 M5 SMG, would be glad to learn
if not pls kindly revise your comments in the posts to avoid confusing others
tks
We've installed over a dozen installations for their customers, and yes there were E60s vehicles as well. Unfortunately, never got a chance to get E60 with active seats nor SMG transmission to test, however we tested X5 M and M3 and the M-setting were working ok. HUD never worked for us too - that's expected limitation of functionality. For climate settings they do have option to control warm/cold in the center vents.
Is there any chance that HUD NAV would work with NBT in a 2006 E60 M5?
It's kind of a deal breaker for me since I love that feature.
Discussion Starter #12
We are working on adding the support for navigation information on HUD, but ETA is not available yet.
Once a solution becomes available, you will be able to upgrade.
Would you provide us with a status update as it relates to the active seats, ventilation, navigation in HUD?
I've seen your latest update: MOST eNBT Retrofit Adapter for E6x and E7x BMWs with HUD and Climate Control Support
Also, any dealers in Alberta?? :grin (your dealer locator doesn't seem to be working)
Discussion Starter #14
Discussion Starter #15
We are excited to announce that we are having a SALE until September 18th. Don't miss your chance to get one of our retrofit kits at a discounted price.
We look forward to hearing from you.
Sincerely,
Bimmer Retrofit Team
*Must be logged in to use the code.
Discussion Starter #16
>>>Bimmer Retrofit: RTTI Real Time Traffic Information<<<
RTTI Real Time Traffic Information and BMW Online services
Bimmer Retrofit is proud to present RTTI Real Time Traffic Information and BMW Online services for all BMW NBT owners.
This is a new and cool feature which will give ability to see Real Time Traffic Information, as well as some additional features, if you have an NBT head unit (installed from factory or retrofitted).
Two packages are available:
Package 1:
• RTTI – Real Time Traffic Information
• BMW Online (News, Weather)
• Internet
• SOS (Emergency Call)
This package will include telematics unit and wiring kit. In the future, additional services will be added.
*You will be required to have your own GSM SIM card with data plan from your local cellular provider.
Package 2:
• Internet
No additional hardware is required. These features will made available via your own cellular phone with data plan. You will need to pair your BT phone and share data connection with NBT.
This retrofit is available for all E series equipped with NBT head unit and eNBT Retrofit Adapter and for all F series equipped with NBT head unit. In both packages your own data plan connection will be used. The approximate usage will depend on many factors but normally stays at around 500MB per month for an average user. At this time we offer this retrofit to all of our NBT retrofit kit customers (NBT for E and F series). Special conditions apply.
For any questions about this retrofit, please contact us:[email protected]
Discussion Starter #18
NBT EVO ID6 retrofit in E-series
NBT EVO ID6 is latest navigation system from BMW, available from factory in G-series and select F-series BMW. NBT EVO ID6 is definitely the best development of BMW yet... and this is the best integration of NBT EVO retrofit in E-series!
We provide everything needed to install NBT EVO retrofit in E-series BMWs. Our eNBT Retrofit Adapters fully support NBT EVO functionality in E-series.
Take a look at our eNBT Retrofit Adapters or contact us for a quote (make sure you provide the VIN of your vehicle).
Watch our video for more information on this retrofit:
That's pretty sweet! But BMW needs to step up their Apple CarPlay game! How's the screen retrofit for the e60? Same as the NBT screen retrofit that fits in the e60 housing or does it lay in front of the old one ?
Discussion Starter #20
NBT evo display for E6x/E9x is assembled the same way as for NBT ;)
1 - 20 of 20 Posts
