1 - 20 of 34 Posts
Well apparently I had a valve spring failure on my '08 M5 with 87k. Exhaust valve spring failed caused the valve to hit the piston, bend and a piece of the valve broke off and welded itself between the intake valve and valve seat. Pictures coming soon. Now we'll see how my exclusionary warranty handles this repair. Thing that sux the most is I was just driving home from work when it went into limp home mode, luckily my Indy is on the way home. I have the USAA (underwritten by Asurion) exclusionary warranty, on my second renewal. The first renewal they replaced my SMG with no issues so I'm hoping for the best.
I bought it in 2015 from another board member with 55k. I was the third owner. Board member (2nd owner) had it less than a year. Bearings have not been done, but planned on doing them this year although my oil consumption is very low and I change the oil about every 6k.
Waiting on the inspector from the warranty company to check it out, but at minimum I think a new head will be required.
VANOS check first and then pics from bore scope
Years ago I had a Ford Escort (circa late 80s) it dropped a valve and wound up on its edge in the top of a piston - hammered the head as one would expect. New piston, new head and $900 later the car ran again - a far cry from a V10.
Keen to see what insurance says. Any caps listed in your coverage? This is likely to be spendy.
** posted before the pics were posted.....
I need to read the policy closer, but it was exclusionary and I don't remember any cap.
good luck
Man I just had those A holes turn me down for a turbo on my Ford F350 ( last year ) cause I had a dirty air filter ( and it wasn't that dirty ) , there was a small amount of dirt past the filter ( it had 80K on it so ya it wasn't like new past the filter in the tube entering the turbo ) . Anyway they said my filter caused turbo failure and denied the claim. their job is to find any reason to turn it down.. So I hope you have service records . cause if they can find a reason like you missed a oil change they will try to say that cause it. I will NEVER buy another extend warranty. Google it cause they are not really warranty's they are service contracts and you do not have the same protection under the law.
Damn that sucks. So valve springs is another big issue with the car besides the bearings?
Sent from my SM-N960U using Tapatalk
Discussion Starter #11
I had never heard of any issues with the valve springs, but apparently it is. If I spent all day at the rev limit racing it, I might have thought it could be a problem.....but daily driving? Would never have anticipated that issue.
You guys are scaring me im going to look at one at newport. There will be no ppi since my local shop doesnt work on Saturdays. It has one owner 38k miles 2009 m5 e60 and alpina wheels that rub when turning the steering wheel.
I can remember one more case of a broken spring in the forum. Someone like Jim would be able to tell if/how frequent the issue is. Another weak point of the engine for sure, but at least seems to be rare rather than the norm like bearings.
Discussion Starter #14
Still waiting on the inspector to show up, but the warranty company has been asking my Indy for all maintenance records on it. Not sure if that's a good sign or not. I've kept it maintained so hopefully that shows.
Discussion Starter #15
Jim?
Discussion Starter #17 (Edited)
Inspector apparently showed up finally yesterday, took pictures and got details so we'll see what happens in the next few days I hope. I miss the beast.
Discussion Starter #20
Still in process. I believe it was approved for up to $11k so the motor has been dropped to get the head off and they are fully assessing what will need to be replaced.
1 - 20 of 34 Posts
