1 - 17 of 17 Posts
http://www.herringtoncatalog.com/m725.html
I've used this brush for a long time and have had great luck!
Hope it helps.
KCD
SpiderSense said:
boy those wheels are hard to clean. too many spokes!
any safe, yet powerful wheel cleaner? i've always used car soap and a sponge, but i'm gonna need help with the M5 wheels.
thanks in advance.
James
I have had good luck with the Zymol Brite and P21S wheel cleaners. Safe for the finsh while being able to remove most brake contaminents from the rim. Hope this helps.
I think car wash soap and water is best. When you let the wheels get so dirty that this isn't enough, and then need something stronger to clean them, I think you're heading down the wrong track, especially since many owners have complained that the OEM wheel finish isn't very durable. I generally wash the car/wheels every other week or so, and have the Axxis Ultimate brake pads which are somewhat less dusty than OEM. I find that soap and water and a small sponge works fine.
The PS1 Gel is great for those really dirty wheels.. you know, the type you get over the winter in areas where it is too cold to wash.
My initial experiences with the PS1 line were a little underwhelming, but as I used it more and more, it seemed to do as they advertised, making the wheels easier to clean.
In Memoriam
Be careful with wheel cleaners. I own a 1.75 year old cherry M5. The car has NEVER been in a car wash and has only been cleaned by BMW dealers and myself (and I never use anything stronger than cold water on the wheel rims). The last time the car was washed by a BMW dealer (who DENIED they ever use acid on the wheels), the wheel finish was ruined on 3 wheels ... the lug nuts now look like they are 100 years old and two of the Roundel inserts are peeling (the car isn't 2 years old, yet). I am negotiating for new wheels, tires (I almost need them), Roundels and lug bolts for about $3,500 (best price I can get from BMW). Ouch, and **** ... BE CAREFUL and don't use anything stronger than absolutely needed on the rims ... Just my free advice ...
I agree with Quick M5. The gun smoke finish on the stock rims is VERY
fragile. When I bought my '03 M5 last year I didn't notice that the rims
had black drops and rivlets all over them. When I returned to the dealer
he explained that this may have been caused by road spray when the rims
were hot (highly unlikely). I suspect that the detail shop sprayed the wheel
cleaner on and forgot them. Result was the dealer replaced all four rims.
I now only use mild car wash soap, a very soft brush and water on
cold rims. Using Zaino on the rims really helps keep the brake residue from
sticking.
For non gun smoke finish rims I use Eagle One All Wheel Cleaner.
It's cheap and really gets the brake dust off. For a complete treatise
on the subject of wheel cleaners, see Guru Reports (www.gurureports.org).
Stacey
Two things I really like...
Bmw wheel cleaner....yeah it acually works, spray the wheel off with water spray this on let it sit a min then spray it off wipe with a towel, and looks great.
The other...go to the store get pure amonia, get a spray bottle, load a little dawn into the bottle about a squart, then about half of amonia, and the rest with water, shake and clean the wheels with that the same as above works great.
1 - 17 of 17 Posts
