1 - 5 of 5 Posts
Hi All,
The best quote have had on a rod bearing replacement in the UK is £1650. Can anyone better that?
I had other work done at the same time which complicated matters - but that seems about what I paid.
Give Redish Motorsport a call in Bristol, had mine done with them along with some other work a couple of years ago):
Rod Bearings (BE Bearings)
Piston Squirters (fitted the later lci ones)
Vanos HP line
Replacement dual drain oil pan (as mines a pre-lci)
They may not be quite as cheap as your quote above but you get what you pay for and for me, they are the best at what they do (I won't take my car to anyone else not even for an oil change)
1 - 5 of 5 Posts
