1 - 20 of 23 Posts
Do you really have rust? From where? Can you please provide pictures? I would say Alpina would not accept this and an email with enclosed pcitures to Alpina Germany would solve this quite fast is my guess.
Sounds crazy but I have to get my wife to take the picture and download it.......but as soon as you slide that cover to the side and look directly into the wheel is where the rust is.it is not just on 1 wheel but all 4 wheels.Seems stange because where would the rust originate from?I will try to post a picture latter but none of you have any rust inside that little cylinder?
Thats it exactly.When you slide the cover to the side and look directly into that small cylinder it is rusty like the picture.Shouldn't the rust be removed so it would not spread or it can't get worse over time.However your picture is not of the wheel itself and what I am desribing is rust on the wheel itself.
The hub is untreaded steel and should stay that way if you want a wheel to properly center. What you describe as a "cylinder" is a hole in the wheel that's used to balance it. The rusty bit you see is the cap in hub itself, not the wheel. If you want to prevent it you can clean it off when the wheel is removed, and lightly grease the edge of the hub. Totally unneccesary in my book, but if it floats your boat......
"Be a good American - sue somebody" :haha:
Discussion Starter · #11 ·
Gustav, no I have not.When Stevie answered it seemed normal.How or who do I email.Secondly, nobody really responded on whether there B7 had rust or not.So I really have no idea whether something is wrong .I was hoping to get the answer from someone here.Thanks!
or marry Paul MCartney........:eek:oohhh:
yea we are sue happy here that is for sure.....and we get a bad rap for it
WoodRanch the rust is normal there. You can get the hubs sanded and painted with Zinc Paint. I have seen many do this.
Discussion Starter · #18 ·
Thank you GaAlpinaowner.I was not sure that was normal because no one else has said the have rust.So far nobody with a 07 or 08 B7 has said they have what I have with the rust.If you say thats normal I believe you....
well they probably have not removed the wheel/tires yet. The part that has the rust on it is on the rotor and hub. Here is what some do to fix:
This is from a porsche forum so do not shoot me
http://forums.rennlist.com/rennforums/showthread.php?t=425156
On my B7 - I painted the rotor hat and hub (Center)
1 - 20 of 23 Posts
