COMMENT 10/03/2011 : THIS DYNO TEST IS NOT ADAPTED TO THIS CAR WHICH REQUIRES DYNAMIC AIRFLOW (see explanation on page 2). THE RESULTS SHOWN BELOW ARE NOT RELIABLE. I WASTED MY TIME AND MONEY . I KEEP THIS POST ALIVE SO THAT YOU DON'T WASTE YOURS.
Yesterday my car passed the dyno test.
Results are the rear wheel were:
327 hp @ 4980 rpm
532 nm @ 3750 rpm
They said their system can measure the drivetrain losses, by measuring the braking factor on the rolls, in deceleration phase.
This led to
50 hp loss at the peak power rotation,thus 377 hp at the crank
55 nm loss at the peak torque rotation, thus 588 nm at the crank
I'm puzzled by these results, because:
power at the crank is deceptive (lower than 400 announced by Alpina, first time I have lower results than what Alpina had announced)
power curve gets its peak before 5000 rpm and then starts decreasing
torque is humoungous but again too early in the curve
drivetrain losses ratio seems very low (13,2 %) taking account it's an automatic-converter gearbox.
I must say it's in total contradiction with feelings (the car is getting an extra-humph beyond 5000 rpm, which the B3 did not have) and with the comparison with my B10 biturbo (377 hp at the crank but 22% drivetrain loss, measured on the same bench) which, in real life, can not play in the same league as the B3S. On 0-200 km/h,the B10 is in the 19 sec range, whereas the B3S is in the 16 sec range. You need a lot more power to achieve this (same weight for both cars).
One cause we discussed with the manager, is that the air inflow might not be sufficient to feed up the turbos, especially after 4000 rpm. But he disregarded this possibility, arguing that his system can produce up to 22,000 m3/hour, and that should be sufficient. Still, with the Alpina Airbox developed by Alpina for the b3S, which contains a vortex system, it might be that this engine is sucking so much air at high rotations, that the fan was insufficient (or not well placed, or not fast enough). I want to further investigate .
It is noticeable that ,calculated with a drivetrainloss of 18 % (which seems a common ration for modern automatic BMW's) , the power at the crank becomes ... 399 hp ! (and 409 with a 20 % ratio).
I dropped a mailto Alpina with the detailed results and graphs,asking for comments.
I will keep you posted. If you have thoughts, happy to hear about, as this ruined my day yesterday :dunno:
327 hp @ 4980 rpm
532 nm @ 3750 rpm
This led to
