What are the correct spark plugs to use on the E31 B12 5,7 ?
C carmel · Registered Joined Jan 16, 2001 · 370 Posts Discussion Starter • #1 • Sep 11, 2014 What are the correct spark plugs to use on the E31 B12 5,7 ?
H horke · Registered Joined Aug 1, 2009 · 260 Posts #2 • Sep 12, 2014 Alpina recommends BOSCH F7 LCR, which nowadays is replaced by BOSCH FR 7 LC 2
C carmel · Registered Joined Jan 16, 2001 · 370 Posts Discussion Starter • #3 • Sep 14, 2014 thank you Horke !
C carmel · Registered Joined Jan 16, 2001 · 370 Posts Discussion Starter • #4 • Sep 14, 2014 Horke would you happen to know the Gap for the Spark Plugs ? thank you,
H horke · Registered Joined Aug 1, 2009 · 260 Posts #5 • Sep 14, 2014 BOSCH ZÜNDKERZE FR7LC2 Elektrodenabstand [mm]: 0,7 Aussengewinde [mm]: 14 Schlüsselweite: 16 Anzugsdrehmoment [Nm]: 28 Pol-Anzahl: 1 Gewindelänge [mm]: 19 Gewindesteigung [mm]: 1,25 Funkenlage [mm]: 5 so ... should be 0.7mm
C carmel · Registered Joined Jan 16, 2001 · 370 Posts Discussion Starter • #6 • Sep 16, 2014 excellent ! thank you ! I can not locate these spark plugs here in the USA. Is there a place in Germany ? thank you again
H horke · Registered Joined Aug 1, 2009 · 260 Posts #7 • Sep 16, 2014 Did you check on ebay - if there are some sellers shipping to the US ? I tried to research an replacement for this ... but it seems that even this cross-refernce-guide is not 100% correct. So - use with caution. BOSCH FR7LC2 - Alternative spark plugs
