1 - 5 of 5 Posts
Hello. Can some one confirm this is the right parts if i want to go the single mass way?. Flywheel M5 3,6 or E28 535? Disc= 881861999867 and clutch cover=883082999765
What about the release bearing?
The stock flywheel is quite thick and causes the clutch disc to be placed further back from the engine. The gearbox shaft might not be designed to handle a clutch disc which is placed closer to the engine. I don't know if you already removed the gearbox?
Were are you located?
AFAIK ,,SM flywheel have been put on many B10 BT,, but the main trick is the throw out bearing,, i have seen a solution they solved it ,,just great IMO i am totally 100 confident that the input shaft is the same length from the bellhousing as on G260 G280,,, why is that ?? yes the end of the shaft would otherwise not get positioned in to the pilot bearing ,,,,,, correct me if i am wrong
931456
931457
931458
1 - 5 of 5 Posts
