1 - 9 of 9 Posts
Looking at one of these that has been standing for a long time in someone's collection.
Unfortunately the 3 ECU units are missing.
So no chance of it running.
It is for sale. What is the likelihood of getting these parts?
Also needs airflow sensor amongst other stuff.
Buy E34 M5 3.6 ECU (bosch 350)
Buy E34 535i M30 EML control unit
Buy Porsche turbo control unit
I can send you the correct EEPROMs so you can put them in the control units.Than your car is ready to run.
Tomba... is B10 BT running Porsche Turbo ECU,,?? or is it possible to run that with another eprom as you say
Interesting. I just purchased,from a local auction, a 1991 B10 3,5/1 with critical ecu parts missing. To date I have procured the following :
  • new motronic 1.3 from Alpina,
  • used standard 535i EML. (was told by Alpina to have the eprom changed, Tomba is your eeprom the same for bi turbo and normal aspirated)
  • remanufactured MAF
  • just in case, used EGS with EML.
plus lots of relays...
I have both (B10 3.5 and B10 BiTurbo) EML and DME files. Of course turbo ECU files for BT.
Code:
EML Module
Prod./Motor.Nr: BB30558
Fahrzeugtyp: B10 3.5/1
Kunde/Handler: ****a
Variante: HG
Motortyp: B11/3
Datum: 25.5.92
1726217
*264.09*    078
*28RT8526*
*6914.054H4*
Bosch: 1 137 328 017  -  0 285 006 003
Alpina: 13 56 638
Code:
DME
Variante: C05A
Motortyp: B11/3
Datum: 25.5.92
1730697 001
*263.30*    810
*26SA1058*
*1545000420*
WBA HD11070 XXXXXXX (removed VIN)
        C05A
1730697
Bosch: 0 261 200 179
Alpina: 13 56 625
1 - 9 of 9 Posts
