I'm confused by this. The fuel pressure is controlled by the FPR on the fuel rail and if it's set at 3.8 BAR tha't the pressure in the fuel rail. If the fuel pump you fit cannot meet the flow demands of the BT engine to maintain 3.8 Bar at Wide Open Throttle (WOT) then you shouldn't fit it. The engine will run lean, you'll run the risk of detonation and damaging your pistons. I've done a lot of tuning work to my E30 M3 and have a deep understanding of the way fuel pressure fluctuations can change the AFR and if I remember correctly, one of the limiting factors to simply tuning the BT by upping to boost pressure was that the injectors were already too close to max duration at the 3.8 BAR pressure, so if anything, you need more flow, not less. Fit the Bosch pump which can maintain 5 BAR and have the FPR control the pressure at the fuel rail - much safer that way! Cheers, Dave.
