ATF Fluid
3722 7
Will be purchasing the below for my vehicle (from halfords as I need it quick):
Description:
Castrol TQ-D fully meets the requirements of Dexron® II D and II E type fluids and is suitable for all transmissions calling for this level of specification. TQ-D is recommended for use in the automatic transmissions and power steering fitted to many other types of vehicle, including later Fords where fluid to ESP-M2C166-H or SQM-2C9010-A is specified. Also for semi-automatic transmissions where a Leyland spec E fluid is specified.
Halfords:
Halfords | Castrol TQ-D Automatic Transmission Oil 1L
Opie Oils:
Castrol TQ-D Automatic Transmission Fluid meeting Dexron IID & IIE
Don't want cause the beast any concern ...... I'm around 90% sure the oil is correct and high grade?
FYI - I've read previous threads on ATF but need a quick answer, hope no one is offended. :confused:
1 - 8 of 8 Posts
hmm....
How in the world do you have an automatic transmission..
you want royal purple synchromax fluid in your transmission..
1 - 8 of 8 Posts
