NOI replaced the clutch line and since I had to bleed the clutch I thought I might as well replace the brake fluid with ATE Super Blue. Well now I have an annoying squeaky noise everytime i press in the clutch pedal. Its definitely coming from outside the car around the slave cylinder/tranny area and it wasn't there before. Can non-oem fluid really cause a noise?
With a new brake line installation, it's likely the upper portion of the slave cylinder is filled with air andNo clutch work done recently, the ate fluid causing a noise sounds weird to me as well, but when i
searched for squeaky slave cylinder a few mentioned the ate fluid they just put in.
Should i re-bleed it?
