Aston Martin AMV8 (V8 Vantage) unveiled at Geneva
1177 Views 1 Reply 2 Participants Last post by  Rickcoin
- Length: 4382 mm (172.5")
- Width (excl. mirrors): 1866 mm (73.5")
- Width (incl. mirrors): 2022 mm (79.6")
- Height: 1255 mm (49.4")
- Wheelbase: 2600 mm (102.4")
- Front track: 1568 mm (61.7")
- Rear track: 1562 mm (61.5")
- Turning circle (kerb to kerb): 11.1 m (36'5")
- Boot capacity: 300 litres (10.6 cu.ft)
- Fuel capacity: 77 litres (16.8 UK gal / 20.2 US gal)
- Cd: 0.34
- Weight: 1570 kg (3461 lb)
Body:
- Two seat, two door body with rear tailgate
- Bonded aluminium structure
- Aluminium alloy, steel, composite, and magnesium alloy body
- Extruded aluminium side impact bars
- Halogen projector headlamps
- LED rear lamps
Engine:
- All alloy quad overhead camshaft 32 valve, 4.3 litre V8
- Variable inlet camshaft timing
- Dry sump lubrication system
- Fully catalysed stainless steel exhaust system with active bypass valves
- Front-mid mounted engine
- Rear wheel drive
Projected Performance figures:
- Maximum power: 283kW (380 bhp / 385 PS) @ 7300 rpm
- Maximum torque: 410Nm (302 lb.ft) @ 5000 rpm
- Maximum speed: 280 km/h (175 mph)
- 0-60 mph in 4.9 seconds
- 0-100 km/h (62 mph) in 5.0 seconds
Transmission:
- Rear mid-mounted six speed manual gearbox
- Alloy torque tube with carbon fibre propellor shaft
- Limited slip differential
- Final drive ratio: 3.909:1
Steering:
- Rack and pinion power assisted steering
- Column reach and tilt adjust
Wheels & Tyres
Standard 10 Spoke Wheels and Tyres:
- Front: 8.5J x 18"
- Rear: 9.5J x 18"
Bridgestone Potenza Tyres:
- Front: 235/45 ZR18
- Rear 275/40 ZR18
Optional 7 Spoke Wheels and Tyres:
- Front: 8.5J x 19"
- Rear: 9.5J x 19"
- Front: 235/40 ZR19
- Rear: 275/35 ZR19
Suspension:
- Independent double aluminium wishbones
- Coil over aluminium monotube dampers
- Front and rear anti-roll bars
Brakes:
- Radial-mounted four piston monobloc calipers
- Dynamic Stability Control (DSC), Traction Control, Anti-lock Braking System (ABS), Electronic Brakeforce Distribution (EBD), Emergency Brake Assist (EBA), Positive Torque Control (PTC)
- Ventilated and grooved steel discs (355mm front, 330mm rear)
More pics
Official Brochure
1 - 2 of 2 Posts
Awesome!
Yellow won't be offered, right?
It sounds like the best driver's car Aston Martin has built in decades.
"The V8 Vantage has endured the most extensive test and development programme in the Company’s 91 year history during which 78 Prototypes were vigorously tested more than 1½ million miles. In Dubai over 12,000 miles of testing was carried out where ambient temperatures regularly hit 48ºc and the bodywork of the cars reached 87ºc.
High speed testing was conducted at the Nardo test track in Italy and extensive testing was carried out at Nurburgring’s Nordschleife in Germany, and cold weather testing in temperatures as low as -30ºc was undertaken in Sweden."
Three must-read articles about Aston Martin and Henrik Fisker:
http://www.motorsportscenter.com/article_491.shtml
http://www.motorsportscenter.com/article_492.shtml
http://www.motorsportscenter.com/article_493.shtml
1 - 2 of 2 Posts
