arrgh, how to remove console lock switch
1386 3
spilled a coke in the car, trying to clean it out, how the heck do I remove the door lock/unlock switch, got the console off but this thing seems to be stuck in it
TIA
Dark Knight
1 - 4 of 4 Posts
if you pull up the gearshift gaitor, you should be able to push up the hazard light switch and then be able to pushup the door lock/unlock button too.
Pull up the shifter boot and reach under the console and from the bottom push up and out on the switch. This is also where the hidden trim screw is so once you do this you can remove the entire console trim piece and really do some cleaning.
When I pulled mine up I found 57 cents which is basically a .001% rebate on how much I paid for the car!
1 - 4 of 4 Posts
