These seem to have been unavailable for quite awhile now. Does anyone have a secret source, or am I stuck rolling the dice on a used one?
That is some very cool information, unfortunately I'm not in a position to experiment right now. Out of curiosity, do all the ZF LF-30s run the same pressure?I went down a rabbit hole with these and found Audi, Benz and others use similar ZF LF-30 pumps but with slightly different pressure/reliefs and low side inlet orientations. I do feel like the E46 M3 version has an inlet orientation that's close enough but haven't confirmed. Bimmer world offers a rebuild of that IIRC.
The problem with rebuilding these is the pulley side bearing, which hides a shaft seal, is held in by the casting somehow. You would have to machine down the lip that retains the outer race of that bearing in order to press it out.
