Are E39 & E46 M-model diffs interchangeable?
120 views 5 replies 4 participants last post by  Ferris
#1 · (Edited)
I saw several threads re lower ratio diff swap from E46 M3 to E39 M5.
is it plug n play or some mods are required to fit?
I want to go from stock 3.15 to M3 stock 3.62
If you have experience with swapping diffs btwn models please comment
#6 ·
The diffs themselves are not interchangeable even if you swapped covers and I don't think the internals are either.
E39 V8's used a pretty unique 215 size AFAIK. Basically nothing interchanges with them.
You know after you mention it you're right about cases I was thinking about the internals.
Edit :
by internal I mean the ring pinion and bearing sets.
