1 - 20 of 29 Posts
Send Rob.. a.k.a. RennSportSC'dKellenersM5 a PM.. he has a custom made set up... :M5thumbs:
Andre,
Im running superleggara III's not the one piece Superleggars that i think metal man is looking for.
Im guessing that he (metalman) is looking for the one piecers since he knows enough to ask about specific rim widths for those wheels.
metalman, I too have superleggaras (3 piece)...
the fronts are 9 or 9.5 and the rears are 10.5
I neeed to know if they are 9.5's
Any clearance problems on big brakes & if they are inside the fender well?
you can run anywhere from a 245-275 f and a 275-295R with those widths
Im currently running the 275F 295 rears from OZ but they had to have the offsets changed to work
so your looking at 265/285 i believe
The oz's have the best clearance for BBKs out there
What are the offsets on the custom set? Fronts 9.5's?
Ok, I give up. What are superleggars? I am assuming a type of wheel, but you never can tell.
Thanks,
Mark
txbeast said:
OZ makes 'em ... Very nice wheel.
Any pics to be had?
Mark
Mark,
they are OZ wheels.
All pics are of my car
When i was running the 245/275's
Now running 275 and 295's
Thanks for the pics.
Mark
Metalman, I've just checked because when I sent you an email I wasn't 100% certain.
Mine are 8.5x19 and 9.5x19, running 245/35 and 275/30, wasn't troubled by the understeer people have suffered, so didn't feel the need to go up to 275s at the front; no problems at all with rubbing even when fully loaded, and clearance with the AP BBK fine, reduced unsprung weight definitely tells with the smaller sizes - not sure if that would still be the case with the larger widths front and back. Actually the spec I have is that suggested by OZ for the M5 on their website.
Roger
you shouldnt have to roll the fenders if your car is lowered, but if the rear is lowered more than about a .8" it will cause problems with 4 people in the car.
So, if you're running 245 F and 275 R and the car lowered wihout any fender gaps, will they rub without fender rolling?
1 - 20 of 29 Posts
