yes you can run a 6 piston 15" setup (brembo in my case) with stock 19's wheels- the 16" kit will not fit.......Can you not run stock 19's with the 6 piston front 4 piston rear setup? I am thinking of investing in a set myself as I need new rotors and pads.
i have stock 19' with brembo bbk. it fits just fine.Can you not run stock 19's with the 6 piston front 4 piston rear setup? I am thinking of investing in a set myself as I need new rotors and pads.
Yes, it fits. I have 380mm brembos bbk.mmmmmmCan't fit 380mm front and rear then?
Yes, I have 380mm yellow brembo bbk right now. And it fits the stock wheel no problem.:haha:Sorry for the hijacking, so 380mm front and rear kit will fit inside stock 19's?
