21 - 27 of 27 Posts
Discussion Starter #23
Oh awesome man thanks for the pics!! Definitely an upgrade over stock!
Alright that settles it, I'm going fully monty when I crack these headlights open and upgrading everything. Ill take some pics and keep this thread updated too, be another few weeks until i get all the parts.
Thanks again!
Thanks again!
I can't remember what size spacers I used. I will remeasure to make it easier for you.
Almost forgot. I used a 15mm spacer with a 1mm washer, or just use a 16mm spacer or standoff. The mounting set up I made used a 21mm M4 hanger bolt, 25mm M4 stud, 15mm x 6mm M4 threaded hex spacer, and 8mm x 1mm washer.
931310
I went EvoX 2.0 as well. Not totally exact fit as notes but close. Had shop do actual open and install, had to return and get some issues resolved. Took too long but end result was modern projectors with "double high beam" and total stock look. Went odometergears for adjusters.
That AE link looked promising, too bad product not available!
21 - 27 of 27 Posts
