1 - 10 of 10 Posts
I just got a e60 m5 with smg. I found that in some situation such as drift to take a u-turn is a little suck without clutch.
So I am considering a manual swap.
there is no manual version in my contry.
6 speed manual is possible using m3 manual gearbox
but why not got u self a bad *** 7speed manual!
I have a great idea that can transforme smg III to 7 speed manual.
Here is it:
smg III is controled by hydralic
first convert the clutch to a pedal that's easy.
second is a little complicated
we need to fabracate a hydralic stick shifter with 4 slider cylinder, 3position each.
although the shift pattern is not a normal manual pattern on smg III but with 8 hydralic cables, we can convert that weird pattern to a normal maunual pattern .
on the gearbox side: mod the 8 cable into stock valve
fill it with fluid.
to the last. flash the ecu to a manual version!!
Any one intrested in this project?
Technical hurdles aside..
I don't think the patterns is practical and prone to driver error and over rev, unless you can do a gated shifter or really long throws.
No,the pattern is not a problem at all. With hydralic lines, we can transform it to a normal pattern
I’ve thought about this before and wondered why it was never talked about... I would be interested if someone developed it! I think it’s as easy as you think though, this sounds like a pretty big project
Good luck.
Yeah,it is possible but a big project
I think you can do it! I look forward to watching the progress.
I once (seriously) converted a Geo Metro from Auto to Manual and from 4 cylinder gasoline to 3 cylinder Kubota diesel. The fun was in doing the project. as long as this isn't your daily I think it could be a great experiment.
1 - 10 of 10 Posts
About this Discussion
6 Participants
planejob
BMW M5 Forum and M6 Forums
Full Forum Listing
