Another tire question
1022 Views 3 Replies 4 Participants Last post by  mottati
26
I have been searching around for a set of tires to put on my second set of stock rims. As we all know the fronts are 245/40/18 and the rears are 275/35/18, but will other larger sizes fit on the OEM rims and also clear the wheel openings?
Finally does anyone have experience with the tires outlined below? They seem very inexpensive, have a long treadlife and come highly recommended by others who have used them on cars other than the M5. As usual it sounds to good to be true...
<TABLE cellSpacing=0 cellPadding=0 width=630 border=0><TBODY><TR><TD width=630 colSpan=6 height=10></TD></TR><TR><TD vAlign=top width=250><TABLE cellSpacing=0 cellPadding=0 width=250 border=0><TBODY><TR><TD class=bold width=250 colSpan=2>
</TD></TR><TR><TD width=75>
</TD><TD class=bold width=175>g-Force Sport</TD></TR><TR><TD width=75>
</TD><TD class=textTight width=175>Great dry handling and affordability. Z-speed rated.</TD></TR><TR><TD width=250 colSpan=2 height=8>
</TD><TD class=bold width=175>275/35ZR-18 95W RBL</TD></TR><TR><TD width=75>
</TD><TD class=links width=175>Reading the Tire Size</TD></TR><TR><TD width=250 colSpan=2 height=13>
</TD><TD width=175>$160.00 ea.</TD></TR><TR><TD width=250 colSpan=2 height=8>
</TD><TD width=175></TD></TR><TR><TD width=250 colSpan=2 height=20>
</TD><TD class=links width=175>(Start a New Search)</TD></TR><TR><TD width=250 colSpan=2 height=3>
</TD></TR></TBODY></TABLE><TABLE cellSpacing=0 cellPadding=0 width=250 border=0><TBODY><TR><TD width=250 colSpan=2 height=12>
</TD><TD class=demi width=175>Specifications:</TD></TR><TR><TD width=75>
</TD><TD class=solid width=175>Treadwear: 340</TD></TR><TR><TD width=75>
</TD><TD class=solid width=175>Traction: A</TD></TR><TR><TD width=75>
</TD><TD class=solid width=175>Temperature: A</TD></TR><TR><TD width=75>
</TD><TD class=solid width=175>Speed Rating: ZR</TD></TR><TR><TD width=250 colSpan=2 height=20>
</TD><TD class=demi width=175>Show me:</TD></TR><TR><TD width=75>
</TD><TD class=links width=175>• Comparable Tires</TD></TR><TR><TD width=250 colSpan=2 height=5>
</TD></TR></TBODY></TABLE></TD><TD width=20>
</TD><TD vAlign=top width=300><TABLE cellSpacing=0 cellPadding=0 width=300 border=0><TBODY><TR><TD vAlign=top width=300>
</TD></TR></TBODY></TABLE></TD></TR></TBODY></TABLE>
See less See more
1 - 4 of 4 Posts
Bmw set the tire sizes up really well, I would leave it as is...Could you get more, yes...Should you, not really, you can fit a 285 on the rear and be ok, but it's not needed. And 245 is pretty much maxed for a 8 inch wide wheel.
a lot of people have had rubbing issues with 285's on the rear. You really shouldn't go larger than 245 on the front wheel as well. Even some brands are a little wider than others in a given size. One think i notice about that bfg tire is a 340 treadwear rating. Sounds like a pretty hard compound, good if you want long life with a performance sacrifice.
I put very little weight on the tire rack surveys. what the average guy says about his tires' performance does not mean a lot.
1 - 4 of 4 Posts
