Ahhh, the latest with the problem child.
Went to start car about a week ago and no joy. Found out that starter was not enabling due to SMG. No codes at the time.
After re-trying got it to start and moved the car to where I can work on it.
NOW (car has sat a bit), I get the following error codes (not all the time after clearing codes):
2B0F - DME: SMG shift sequence monitoring
4FA0 - SMG: Clutch (activation, position deviation)
5101 - SMG: Hydraulic pressure sensor --also at one point in INPA the pressure read ~108 bar, which I don't believe.
Kind of stumped, thought I had this thing running well with regards to the SMG. Other than the above it shifts/runs very very well.
Also, after clearing codes all is well until I step on brake then it throws a RCOD immediately. Start does not enable.
Any ideas?
PLCD sensor wiring perhaps? Maybe hydraulic pressure sensor kaput?
The other weird thing is that when sitting in the driveway after turning off the ventilation system, it kept coming back on! WTF?!
Any ideas?
