1 - 20 of 32 Posts
Hello :sad1:
Now it has happened.... Last thursday after changing to summer tires, I started the car and it sounded like a concrete mixer.... Obviously I didn`t drive the car after that.
Took it to a BMW specialist and obviously the timing chain tensioner has quit its day job.... totally slack chain.
The cam prockets were quite worn also.
Now I`m just waiting for the final judgement: Is the engine history , i.e have the valves had a hot date with pistons lovelove
The worst part is that I planned to change the tensioner at next service.....
Well well...
:crying2: :crying2:
Sakke
[email protected]
'hells bells' that is really bad news, you hv my sympathy - :sad2: :grrrrr:
what is ur present mileage ??
I also have an -upgrade chain-tensioner- lying around together with a new
waterpump 'to be done sometimes', bcs the engines runs smooth with NO clicker sound at all even under cold start I hv had no hurry until now -
your story makes me think....... ?????? ??????
M5touring reg said:
[email protected]
Hi Karl!
Thanks. :sad3:
The current mileage is 190 000kms(~114000miles)
The engine has been reasonably quiet until now....
Sakke
DrSakke said:
Hi Karl!
Thanks. :sad3:
Sakke
I agree with Karl this is bad news you have my sympathy.....:sad2: I hope you can get the car back on the road.
Simon
Simon
Hi!!
The valves have not made contact with the pistons. Im having the whole timing chain, tensioner etc. replaced, I think I`ll have the top owerhauled also while I`m at it....
The tensioner had stuck and was compressed when they pulled it out.
cherrsagai
Sakke
DrSakke said:
Hi!!
cherrsagai
Sakke
Hello Sakke
Please consider the wear on the chain sprockets. They should be changed if the chain is replaced. New chain & old worn sprockets is not good.
Regards
Farrell
farrell said:
Hello Sakke
Regards
Farrell
Hi!
That`s the etc. part in my last post. I`m going to have everything , that is possible to change, changed.
Going to post prices, required work and what gets done when I have the facts available.
:eek:oohhh:
Sakke
Geach said:
Think I need to look into changing my tensioner also, starting to get a little noisy,Is it a big job? Is there a recommended mileage? my car just turned 90 000 miles,'90 model.
Hi!!
Not a big job, An experienced BMW mechanic does it in half an hour, I`m told. Tensioner costs ~70£.
Do it.
There isn`t a specified mileage for the change of the tensioner, Noisiness is one reason to do it.
:cheers:
Sakke
Discussion Starter #13
Cyrus said:
What kind of noise does a worn tensioner make?
Hi!!
Well, the tensioner itself doesn`t make any sound, but it is the timing chain that starts to rattle, especially at startup from cold. Rattling noise from the front end off the engine/"noisy engine"
Can`t describe it any better, somebody else give a try?
cherrsagai
Sakke
raymond woertman said:
Please read This Article about the installation of the S50B32 tensioner in the S38 engine.
Very Good Article Raymond.
Excellent technical content & well written.
I did not know this article existed but had received other information about 2 yrs ago on the tensioner used on the E36 M3 EVO. I had already replaced the std tensioner a couple of years before this. I have the Evo M3 Tensioner fitted to mine just a few weeks ago as an oil leak using the std tensioner had developed.
Regards
Farrell
Discussion Starter #19
Hi all!
Well, I have received the first price estimate for the work and parts..
Parts (Timing chain, guides,tensioner,sprockets, top gasket, top bolts etc ) 12500NOK= appr. 1500eur
Two days labour 10000NOK =1200eur
Plus the price for the labour for overhauling the top ~1000 eur
Total cost est. 30000-32000NOK = 3500+ eur :sad2: :eek: :mad:
I`ve got the downpayment blues.......
:typing:
Living on oatmeal
Sakke
Been out and bought M3 3.2 tensioner today. £62 from BMW apparently its been modified from original will post as soon as fitted to let everybody know how I got on! Thanks to Raymond for pointing the idea out!
1 - 20 of 32 Posts
