So I've read through a lot of the DIY threads and whatnot regarding the drive shaft and bearing and what-not. I'm not sure what my best option is.
Here is a rundown on what I'm working with:
Currently 130K on the car
At around 110 I swappen in a Dinan Rear end....did not drop the shaft at this time only disconnected and reconnected the rear end.
At around 125 I installed a new UUC V-12 clutch and had all the seals, tubes, etc replaced on the trans, basically every serviceable part was replaced, which obviously involved dropping the trans, driveshaft, etc.
Ever since then I gat a 'whomp whomp whomp' sound with a bit of vibration at about 4K rpm. It is not harsh, but it is constant. It will vary based on load, speed, etc.
I'm pretty sure that due to a combination of the service and dissassembly of the shaft it probably pushed the bearing over the edge and needs replacement.
So, because of the mileage, would it be in my best interest just to replace the whole assembly? If a bearing is still the best option, am I going to run into any other issues during replacement because of the mileage.
Any help or suggestions are appreciated.
Thanks!
Thanks!
