Well, I opened up the lights and removed the Amber lens and painted it
Was a heck of alot easier than the ones I did on my X5.
Here is how...........
Remove headlight assembly
Remove any trim and gasket pieces
Get out your trusty heat gun from Harbor Frieght (19.99)
Remove the two screws from the amber end of the assembly
Fire up said trusty heat gun
Take a deep breath
Warm the seams and begin to seperate the front and rear portions.
-It is helpful to have a friend pulling the parts apart while you heat the seams
Once the pieces are apart remove the amber lens
Prime and paint the lens
Re-install with a dab of superglue just to make sure it stays put
Heat the black glue again. Just a bit.
Apply Black Latex Caulk from Home Depot (1.99) all around the seam (on top of the old glue is fine)
Re-assemble the halves
Re-install the two screw
Put back in the car
Notes:
I buffed my lens while it was out and while I was waiting to re-install the Amber/Silver corner back into it.
I also used alchohol to clean the inside of the lens so there were no finger prints on the inside (bad to see once the halves are re-assembled).
On the X5 and the M5 I had some condensation for some odd reason (I know it was sealed REAL well). I removed the high beam bulb for a day or so and let it get good and dry and have not had issues since. My thought is that the caulk is drying thus giving off some condensation.
Here is the result:
Take a deep breath
Put back in the car
Notes:
Here is the result:
