1 - 5 of 5 Posts
I have searched and not found a decent answer on this.
On my X5 I removed the amber corners by splitting the housing (used a heat gun and resealed with black sealant). The amber corner was attached to a clear portion. This just popped out and I used a dremel to cut off the amber version. I am wondering if the same structure is in effect on the M5 front lights. Has anyone cracked open the housing and looked B4?
BTW this is on a 2001
Here are the results from my X5 mod.
Interesting - on my 2001 I have had both replaced (twice) due to moisture. I would think this introduces that risk into the mix - any issues on the X5?
Of course then again it could reduce it all together...
-Jeff
I had a bit at first due to being stupid.
I then removed the high beam bulb for a day and it all dried out just fine and still they look great.
I know on the angel eye style lamps you can pop the amber piece out, but it looks very odd when the piece is gone and you also have a bright white light where it used to shine through the yellow portion for your sidemarker. I chose to leave mine in, but you could always paint it white or black if you wanted.
1 - 5 of 5 Posts
