I haven't got pictures yet. The Plug is a good 3cm wide and 1 cm thick. The wire it self is about 1 cm thick.M-Fünf said:Whoa! I think you're right...that's going to take some thought. You're going to need to route the phone connection wires under the storage tray toward the rear of the car, and then probably cut a hole at the back of the tray to bring the wires up through that, then connect the wires to the bottom of the phone tray... hmmm
Do you have any pictures of the bottom of the phone tray where the wires connect that show the connectors and the size of the wire bundle? If so, post them or send them to me and I'll take a look if you'd like...I can go out and look at my setup and see if there's an "easy" way to do this...
Good Luck!!!
:cheers:
Do you have the phone with the tilting arm rest?
I'll try and take pictures later on and post them.
I'm going to think long and hard but there must be a solution. Every problem has a solution or there is no problem.
