1 - 11 of 11 Posts
I just had to post this here. First, thanks to others posting here on the installation process, I was able to confidently direct my mechanic on how to ensure the O2 sensor cable would fit. Based on a member here's description, we fnnished the job confidently with their comments on initial concern but completin showed everything was fine.
Secondly, the performacne improvement. I really didn't know what to expect but I can tell you, there is a sigfnificant perfromance increase. Not necessarily HP increase but responsiveness. WOW. The throttle dip in garners almost immediate response where I always felt some minor signs of turbo lag and disconnection to the DCT. It was minor but now it feels as if it was significant. Not now however. The power band almost feels more linear with the better breathing exhaust. The car feels that much quicker.
The turbos are much more pronounced in sound now when starting from a stop. I like the sound from the cabin and the sunroof open. The car sounds like a turbo technological masterpiece.
But the real reason I wanted this upgrade was for the exhust sound. From idle there is not much differnece from stock but when you initiate WOT look out. The pops and burbles on upshift and downshift are remarkable.
While a pricey upgrade I think it is worth every penny. I will dyno the car with the catted sport pipes and eventual exhaust. I was going to change to a Race exhaust but I think the combination of these down pipes and Sport exhaust will be perfect.
If you were on the fecne as I was, do it. You will fall in love with your M5 even more.
Do you already have a tune to take full advantage of the DP's? When you say sport exhaust, is that the M-sport (made by Akra) or the Comp Pack exhaust? I'm asking because I want to change out my DP's as well, but keep the stock CP exhaust.
My M5 has the competition package and I still have the stock exhaust after the downpipes. I don’t have a tune to the ECU as I am trying to avoid that. I am debating swapping out the rear exhaust cans for Esienmann Sports. Hope this helps.
Any thoughts/impressions now that you've had it for a while?
Now that I have lived with the car and the Dinan Stage 1, I have to say the car is an absolute animal. My wife says the car "startles" her when I start it with the cold start then when it idles it has a very nice deep tone. Hitting WOT and the car sounds amazing but more importantly, the power is immediate and non stop. The Dinan smoothed the edges a fair bit but the power is unreal. Tires spin al the way through third gear now. I also get a much better soundtrack out of the exhaust. Upshift backfires are nice, downshifts are perfect and the turbos sound amazing. Best upgrades I could have wanted. I had an E60 M5 with an Eisenmann exhaust and while to this day that still sounds better, this car now sounds like a true race car but not over the top.
How bad is the fuel smell?
Want to let go of your old downpipes?
Hi my is Rej I have a2013 M5 F10. When you installed down pipes did you have problems like (malfunction misfire.......)and if so how can I fix the issue, I want my baby back . Thanx I need help ps.
Discussion Starter #11
I have not had any issues with the engine at all with the downpipes. I stayed conservative with catted downpipes but no engine codes, no performance issues at all. Which pipes did you install? The O2 sensor location on the pipes could be the issue. When I was buying them, I called Alpha and spoke to them about the placement of the sensor connnections. They were very careful to have them in the exact right place to stock placement.
1 - 11 of 11 Posts
