1 - 6 of 6 Posts
Hello all
Having a few issues with my car. It is stalling when coming to a stop or putting car into neutral at highway speeds. Doesnt do this everytime but it is rather embarassing and somethings not right.
Car runs great off idle. Sometimes a slight hesitation when pushing gas from a stop
Currently on stock tune to rule out tune being an issue.
NEW
-Mafs
-precat o2
-Air filters
-Swapped in another IACV
-CPS are only 3 years/30k old
-vanos seals done same time
Only concerning thing is the code says "Short circuit to battery or value too high" Not sure what that could be
Have seen this code before and only occurs at idle RPM
Thank you for ANY help
Stock car with muffler delete and dinan cold air.
Well it's clearly not happy with your MAF values for some reason; did you make sure to clear/reset the adaptations/fuel trims when you put in the new MAF? Do you have your old MAF? First tests I'd run would be to put the old MAF back in and/or just unplug the new MAF and see how that changes things.
Did this with old mafs and my backup set.
I was an idiot and bought brand new and still same issue.
Yes have reset adaptations right away after a new part and then few days later just to try. Have been trouble shooting for a week
Next step is a smoke / leak test unless better ideas
1 - 6 of 6 Posts
