741 - 754 of 754 Posts
Hi all finally found a forum that answers questions on this problem, just changed my exhaust camshaft sensor on bank 2, £150 for the part, now its showing the solenoid on the same camshaft
Does anyone know how long is it to have these shipped to the UK not to sure to order 2 for bank 2 or go the full hit and get 4 even though 3 out of the 4 are good,
Ps in the UK BMW want £800 or $1037 each 🤯
What exactly was your issue?
Original problem was limp mod etc, had it diagnosed with the exhaust camshaft sensor bank 2, changed this and still the engine light was one, so the garage scanned it again and it now has the vanos solenoid exhaust side bank 2
That's not a bad price for genuine BMW. Here they're like $1700-$1800 each these days.
Sent from my Moto Z (2) using Tapatalk
Hi All, Sophie v2 Solenoids installed today at ~140,000kms. Results below but I am confused as there are 2 different quality readings within the 1 test.
This one seems to show the valves as OK:
934012
This shows all not ok. However I compared these values with those I did 6M ago and they are the exact same figures to the second decimal place so not sure if these are actually affected by solenoid valves at all!
934013
Detailed review summary on the V2 solenoids (After 4 Bleeds - Codes Deleted after each):
1. Valve current Not OK on all solenoids.
2. Min Stop Not OK on Intake cylinder bank 2.
3. All other values OK.
The valve quality in the individual reports are(0.7,0.7,0.7,0.8) - ALL OK
Th valve quality on front page is (0.54,0.58,0.54,0.55) - ALL NOT OK - Exact same value as I have obtained on old original solenoids 6M ago
Driving wise:
1. Idle seems quieter than before.
2. Engine revving seems a little "lighter"...Possibly more responsive.
3. Maybe a slight improvement in performance (acceleration). I say maybe because car was left at Dealer to perform this work over the weekend and I had an X3 2.0D loaner. So maybe the "slight" improvement in acceleration comes from me driving the X3 over the weekend.
Install was performed by Autoclassic BMW (BMW Dealer here in Perth)
Welcome all comments and feedback. Will post further results later on - Long Term
I would suggest that those ARE the original values from 6M ago and that ISTA did not reset those values in that test. I seem to remember something about clearing tests - or results not being cleared from prior tests.
Hi gmak,
First thing I made clear prior to install was to delete codes and they even stated that on the paper work they gave me.
934014
Driving wise:
Can you provide on how these are doing in the car?
