The system that was tested on the M3 also utilizes the factory air box with a new intake tube and their filter but it still didn't produce any gains in that test.Thanks for the ebay link!
The review done I believe is the AFE Stage 2 setup (open element style). The one I'm looking for results from in just the drop-in filters (utilizes factory boxes) with the scoops. Thanks again!
How is it propaganda when it was tested by a magazine at aFe's own facility using their dyno and dyno operators? And aFe is also an advertising sponsor of that magazine?Propaganda...
Buy the AFE setup, dyno it, and report back.
If it sucks, toss it on eBay.
I certainly believe the results of the tests done, meaning no gain..... but its kind of hard to believe that the RPI scoops and BMC filters makes a relatively significant gain and this wouldn't. They both have scoops, they both have better flowing filters over stock which are contained in the factory air boxes and the AFE system actually comes with smooth tubes to replace the factory 'baffled' units...there's also been a slight debate about the surface area being larger on the AFE filters vs the BMC panel filters. I know that the majority of the gain is from the scoops and of course a higher flow filter (should, in most cases) produce better results over the factory filters. That being said, I'm also finding it hard to believe that this particular AFE system couldn't gain the same or similar results as the RPI/BMC setup. Thoughts?
For what it's worth, we went through a HUGE number of designs before we came to our current one. Many of them would lose power, wouldn't make a difference, or would only change the power by a few hp. We have boxes and BOXES full of pre-production designs that we went through. We spent many many hours dynoing with various fan distances, as well as time on the road. Even small changes in the angle or curvature of the scoop would yield reproducable differences when put through vigorous testing.I certainly believe the results of the tests done, meaning no gain..... but its kind of hard to believe that the RPI scoops and BMC filters makes a relatively significant gain and this wouldn't. They both have scoops, they both have better flowing filters over stock which are contained in the factory air boxes and the AFE system actually comes with smooth tubes to replace the factory 'baffled' units...there's also been a slight debate about the surface area being larger on the AFE filters vs the BMC panel filters. I know that the majority of the gain is from the scoops and of course a higher flow filter (should, in most cases) produce better results over the factory filters. That being said, I'm also finding it hard to believe that this particular AFE system couldn't gain the same or similar results as the RPI/BMC setup. Thoughts?
So you didn't just bend some metal and paint it?For what it's worth, we went through a HUGE number of designs before we came to our current one. Many of them would lose power, wouldn't make a difference, or would only change the power by a few hp. We have boxes and BOXES full of pre-production designs that we went through. We spent many many hours dynoing with various fan distances, as well as time on the road. Even small changes in the angle or curvature of the scoop would yield reproducable differences when put through vigorous testing.
Please don't get me wrong. I'm not making any assumptions or statements as to the R&D man hours put into this by our competitors for their products. However, in terms of our products, and especially for this specific vehicle, it took a huge investment in design time and testing to arrive at the power gains for the RPi scoops.
