Good day all
2007 m6 convertible with 120 000km (approx. 75000miles).
Car recently threw an engine malfunction and reduced power warning, with red line reduced to 7000rpm.
BMW has diagnosed the car as having a fault with the electric oil pumps (circuit showing 'open' I think).
The tech says its an oil pan off job and has recommended that I change both electric oil pumps and the main mechanical oil pump. He tells me that the mechanical oil pump could be failing/starting to disintegrate, which could be causing the electric oil pump fault, and that at this mileage its recommended to change all oil pumps.
Can a member with experience/knowledge of this issue please advise if the BMW tech's recommendation is a sound one?
Obd code attached.
Much appreciated.
Obd code attached.
Much appreciated.
