1 - 2 of 2 Posts
Found moisture in the front passenger headlight.
I took it apart, dried it out and resealed it. Now I have an Adaptive Headlight warning and they do not appreciate to move when turning.
I did the battery reset with no change.
Any thoughts?
Any thoughts?
Unless you removed both modules on each headlight and check for moisture damage he will still have problems. If there was a fair amount of moisture especially on the bottom module of the Light housing you may have blown the actual module. You need to remove the headlights again pull off the bottom modules and look for water damage or corrosion.
1 - 2 of 2 Posts
