1 - 7 of 7 Posts
Company Representative for Active Autowerke
Hey Guys,
Starting today and through out the Thanksgiving Holiday an Active Autowerke Power Pulley will be included with the purchase of our Signature Exhaust and Performance Software.
Literally unleash the beast over night with this complete performance package.
Please post any and all questions. Phone calls and emails are also always welcome.
Thanks for looking.
Discussion Starter · #2 ·
Hey Guys,
Here is some more info on the Power Pulley:
Looking to increase your V10's power ourput? Look no further. The Active Autowerke Signature V10 Pulley kit is a complete bolt on kit engineered using Aircraft Grade Billet 6061 Hard Coat Anodized Aluminum. After months of R&D in house and overseas (various climates & conditions) we concluded that there may be a slight power increase by going smaller than our pulley but the trade off is a chance of making the engine run hotter or possibly overheat, we choose reliability over that extra 1-2 rwhp that we may get from a smaller pulley. Another key element in the development of the Signature Pulley Kit was to retain the “Factory Crank hex Drive Adapter”, this was important to keep this factory feature for its inherent purpose. The pulley kit does not modify factory harmonics or dampening. Stronger side walls were the last key element in choosing our size over a smaller design. The Active Autowerke Signature Pulley Kit yields gains of 12+HP on a completely stock car. This is a complete bolt on system that is easily reversible. A must for the true enthusiast.
Key Features:
  • HP gains: 10 RWHP ~ 12+ HP
  • Complete Bolt on System and is easily reversible
  • Aircraft Grade Billet 6061 Hard Coat Anodized Aluminum
  • Retains Factory Crank Hex Drive Adapter
  • Includes Replacement DRIVE and A/C Belts
  • Does Not Modify Factory Harmonics or Dampening
  • Reduces Rotational Mass
  • Does not cause overheating found in smaller pulley designs
  • Paired with the Active Software for Additional Gains
can i get more info on the software please.
The Active Autowerke Performance Software for the M5/M6 will deliver your V10 motor to new heights. Through careful remapping to the DME and countless hours of tuning this ugprade covers all essential aspects to deliver horsepower and torque gains throughout the RPM curve. Areas that are addressed include fuel,ignition,speed limiters, etc. Our engineers have also made adjustments to part throttle maps to allow for crisper/smoother shifts for an improved driving experience. The Active Autowerke upgraded software is designed to operate with gasoline that has an average octane rating with full emissions to create a clean burning combustion with good AFR’s all within factory specifications.
Key Features:
  • Horspower gains throughout RPM range
  • Higher torque over factory settings throught RPM range
  • Recalibrated settings for a smoother and more responsive part throttle transition
  • Ability to tune all DME's
  • Modified Vanos camshaft remapping eliminating rough cold start enable
  • Top speed limiter removed
  • Raised RPM thresholds in sepecific gears
  • Crisper/Smoother Shifts with SMG Transmissions
  • Tune available for 91 or 93 octane fuel
  • Free tech support and assistance
Performance Specs:
  • 18 HP @ 8400 RPMS
  • 15 Ft / LBs @ 6850 RPMs
Can i get it done in Canada? Toronto
Key Features:
    [*]Modified Vanos camshaft remapping eliminating rough cold start enable
Performance Specs:
  • 18 HP @ 8400 RPMS
You guys at AA might want to modify the above (quoted) post and remove the bolded part. I recently had your tune done and was informed that you do not offer the "Cold Start Removal" for the M5/M6, only for the M3.
1 - 7 of 7 Posts
