So I was driving to Dallas last night from my house, (about 30 miles) when I noticed that my a/c system wasn't really blowing hot air. I had the temp for both zones set at 85 and it didn't seem to matter if I moved it up or down 5-10 degrees. If I turned the center vent temp dial to full hot it would heat up some, but it didn't seem like enough heat for full hot. A possibly important piece of info here is the SES light I had last week, code 69 on my peake scan tool. (engine coolant temperature, plausibility) The code turned off when I filled up the gas tank. The last time I got gas was in december since my car was out of action for 3+ weeks while I was replacing the clutch. Also I need to replace the plastic panels under the front bumper, aka the exploding curb boxes. I know the outside air temperature sensor is located in the pass cover.
So, number one, is something amiss? I haven't had the car long enough to experience all the norms for things like a/c temp response.
If something is wrong, where should I start? ECT switch, thermostat, something else? I do plan on replacing the front bumper covers soon anyway.
As always, thanks guys! :cheers:
-Brian
-Brian
