Agreed. Also, Pirellis run wide. 285 will rub. Stick to 275 on a 9.5 wheel.timmay77 said:Seriously? You couldn't search for one of the 8000 tire/wheel threads we have on here?
BMW runs a 275 on a 9.5" wheel, obviously. A 19" wheel with 285 may rub depending on your ride height. Some of the Dinan wheel owners are running 285's on their 18x9.5" wheels but I believe the offsets are different. I would have to search to be sure, but I think I will leave that up to you......
Yes will be fine on stock suspension. If lowered, may require fender roll.kevin300z said:What about Front 19 x 8.5 / Rear 19 x 9.5 Offset:
Front ET18 / Rear ET20, 255 front and 285 rear with Hankook v12?
You're running that square front and back? No spacers required? Pics please!I run the 285 30 19 on my 19x9.5 wheels with stock suspension and have no rubbing issues whatsoever. BTW i have the hankook v12's. Once I fit my bc coils I might have to go back to 275 but we will see .
With ET 20-25, that should be fine.How about 285-30-19 on BBS LM 19*10? will that rub the rear?
