Here you go.
I did a search and didnt come up with anything. If this is a duplicate - moderators please feel free to delete.
In case you are not aware - 2011 Navigation DVD map of US is now out.
I found this online seller and have ordered mine.
Buy it Now - 2011 BMW Navigation DVD Maps
It arrived last week and everything works great.
Due to huge database info, 2011 DVD map is now split into two DVD's.
DVD 1 is East region, DVD 2 is West Region.
The 2011 version now also includes red light cameras and speed traps.
For our E63 M6, you will need to order the "Professional" version.
Note: I have no affiliation whatsoever to the seller, just sharing info.
See below for 2011 DVD map photos and loading instructions.
1) Get inside your car and press engine start button once without stepping on the brakes.
This is like accessory mode. (Stepping on the brakes will start the car.)
2) Wait about 1 minute for Nav system to boot up.
Once you see maps on your navigation - press eject button to remove your current DVD map.
3) First time you insert the new 2011 DVD, the system will recognize a new version of map.
It will ask you to shutdown your system, wait 5 minutes, then re-start navigation again.
This is because the DVD downloads a new firmware version to the nav drive to support the new DVD map version.
To shut system down, (do not step on the brakes) press engine start button (this is position II on normal engine
switch), then press and hold the engine start button again for about 5 seconds. This shuts the system completely
down similar to removing the ignition key.
4) Wait 5 minutes, then press engine start button again without stepping on the brakes (accessory mode)
Wait for Navigation to boot up completely. Enjoy!
Explore the DVD. If you go to Info mode - you will see red light cameras and speed traps similar to photos below.
Enjoy!
Dan
Enjoy!
Dan
