1 - 20 of 30 Posts
I joined this board almost 9 years ago, when I was driving around in a toyota tercel, in the hopes of one day getting an M5. That time may be soon, as I'm looking at a few CPO 2008 M5s at local dealers. I've never bought a used car (have leased new) so I had some questions:
1) How much room is there in the prices you see for CPO cars on bmwusa's website? Order of magnitude - is it generally a few hundred or a few thousand? I'd like to get the price as low as possible before considering the the $1,500 bmwfs payment credit (and $500 CCA rebate)
2) Before I buy, I want to bring the car to motor works west in wyckoff to do a thorough PPI. What is the procedure to take a dealer's car to get inspected at an indy shop when you don't own it yet?
3) One of the cars I'm interested in is an Interlagos Blue/Black with 29,000 miles that was owned in NY/NJ: Carfax here
Anyone know anything about it? Can someone provide a service history?
4) Once I'm past the 4yr/50k original maintenance, what can I expect normal maintenance service to cost roughly (oil change, brakes, etc)?
5) Anything else I need to be careful about with a CPO M5?
your help is appreciated.
I can answer question number 4; oil changes are $250 and the front & back break job from the dealer is $3000.
Several owners have had SMG faults but not failures. I have 48k miles and no real issues except the dang "increased emissions" light keeps coming on. I did purchase the extended maintenance program to cover the maint for two years. :viking:
Reactions: petesamprs
wow $3k is no joke. why not just get a bbk when your brakes go?
How many quarts of oil does the beast take?
Is the 3K brake job due to the brake size or is there an access issue?
Sensors expensive?
Brembo brake kit will probably run 4-5K (parts cost) would be my guess.
owing a M5 requires a huge investment. You will find dealers won't budge that much on CPO;d cars b/c of the investment they put into it. CPO'd cars are usually anywhere between 3K-6K more than what a non-CPO'd M5 would be.
Secondly, ensure you have funds set aside for when the maintenance warranty, and the car warranty run out. That and weekly fuel costs since mpg is 11 city, 17 hwy. The CPO'd warranty is not the same as the original warranty in that it doesn't cover everything. Make sure you read the fine print between the 4 yr or 50K warranty, and then the extended CPO warranty of an additional 2 yrs or 100K. These cars are expensive to maintain and when they break, costly to fix. If this is a concern, i would say perhaps invest in something else. Otherwise, CPO'd is the way to go for piece of mind.
Hey Pete, Pete Sampr was a fun player to watch.
I also am searching for a good deal low milage 08/09 M5.
Your questions are very important to me as well.
How do you arrange an out of state PPI.
How do you get permission to go to an indy and what can you expect for your money?
Does PPI bear any more real value over an educated/experienced opinion?
Looking for good replies from experienced members.:flag:
Has anyone actually read the fine print and do the comparison and made a list? I think that would be of great help to many. I would do it if I know where to get a hold of the full contract of the CPO. Only just "lists" the items and says iDrive isnt covered but its not specific.
if i'm not mistaken, you can find it on bmwusa.com
Bottom line, the original 4 yr or 50K warranty (US) covers everything so long as it is not the driver at fault and major wear/tear items like tires. The extended warranty is more major mechanical, electrical, and power train stuff, etc.
Discussion Starter · #9 · (Edited)
Yeah the BMW website is pretty specific in terms of what is covered and not covered under the CPO warranty.
On #2, the dealership told me they could have one of their techs drive the car out to the shop for the independent PPI.
Regarding the PPI, when we purchased the M3, I told them I wanted to have the car looked at by the mechanic at a local used car dealership (where I worked for a Summer). In this case, I arranged a time with the mechanic at my old work and told the salesperson, and he drove the car down for its inspection. Each dealership is different (maybe they will let you drive the car to this place...or you can have your mechanic come to where the M5 is being sold and he can inspect it there). Either way, its a pretty seamless process.
Also, regarding warranty, I'd recommend the 6 year, 100k mile extended warranty. Either that or find a cheaper aftermarket warranty (many members here have had great experiences with Easycare warranties). While 08 M5s are pretty reliable, they are still very complex cars and you should be prepared for a potentially expensive repair somewhere down the line.
Good luck, and congrats on finally being able to buy yourself an M5! I'm looking forward to the point in my life when I can make the money to get an E60 M5 for myself :wroom:
afc1
<input id="gwProxy" type="hidden"><!--Session data--><input onclick="if(typeof(jsCall)=='function'){jsCall();}else{setTimeout('jsCall()',500);}" id="jsProxy" type="hidden">
Discussion Starter · #11 ·
Thanks. That's what the dealership will do. I read that the main M5 guy at MWW left and started his own shop in Mahwah, so I'll be taking it to him instead.
The car is a CPO so it comes with the 6 yr, 100k extended warranty. Bigger question is whether I should get the extended maintenance given I have <2 years before factory maintenance runs out. Main driver for that is whether the brake job will fall within the next 2 years (don't get EM) or after (get EM).
afc1
Wow Pete
It sounds like you may have found a great car.
Have you seen it yet?
If the PPI goes well; then you might work the extended maint into the deal.
I'm sure you have thought of this.
I hope they don't say this is an as is deal.
Is there a period of time the car will be purchased back? Might try to work that in the negotiations as well.
The car is a <leo_highlight style="border-bottom: 2px solid rgb(255, 255, 150); background-color: transparent; background-image: none; background-repeat: repeat; background-attachment: scroll; background-position: 0% 50%; -moz-background-size: auto auto; cursor: pointer; display: inline; -moz-background-clip: -moz-initial; -moz-background-origin: -moz-initial; -moz-background-inline-policy: -moz-initial;" id="leoHighlights_Underline_0" onclick="leoHighlightsHandleClick('leoHighlights_Underline_0')" onmouseover="leoHighlightsHandleMouseOver('leoHighlights_Underline_0')" onmouseout="leoHighlightsHandleMouseOut('leoHighlights_Underline_0')" leohighlights_keywords="cpo" leohighlights_url_top="http%3A//shortcuts.thebrowserhighlighter.com/leonardo/plugin/highlights/3_2/tbh_highlightsTop.jsp?keywords%3Dcpo%26domain%3Dwww.m5board.com" leohighlights_url_bottom="http%3A//shortcuts.thebrowserhighlighter.com/leonardo/plugin/highlights/3_2/tbh_highlightsBottom.jsp?keywords%3Dcpo%26domain%3Dwww.m5board.com" leohighlights_underline="true">CPO</leo_highlight> so it comes with the 6 yr, 100k extended warranty. Bigger question is whether I should get the extended maintenance given I have <2 years before factory maintenance runs out. Main driver for that is whether the brake job will fall within the next 2 years (don't get EM) or after (get EM).
I would go for the extended maintenance, unless you have a good independent shop that can perform regular maintenance for less.
afc1
<!-- Top iFrame --> <iframe id="leoHighlights_top_iframe" name="leoHighlights_top_iframe" title="leoHighlights_top_iframe" src="about:blank" vspace="0" hspace="0" marginwidth="0" marginheight="0" allowtransparency="true" style="position: absolute; top: 0px; left: 0px; width: 520px; height: 294px; z-index: 2147483647;" width="520" frameborder="0" height="294" scrolling="no"> </iframe> <!-- Bottom iFrame --> <iframe id="leoHighlights_bottom_iframe" name="leoHighlights_bottom_iframe" title="leoHighlights_bottom_iframe" src="about:blank" vspace="0" hspace="0" marginwidth="0" marginheight="0" allowtransparency="true" style="position: absolute; top: 294px; left: 96px; z-index: 2147483647;" width="" frameborder="0" height="" scrolling="no"> </iframe>
<script defer="defer" type="text/javascript"> var LEO_HIGHLIGHTS_INFINITE_LOOP_COUNT = 300; var LEO_HIGHLIGHTS_MAX_HIGHLIGHTS = 50; var LEO_HIGHLIGHTS_IFRAME_TOP_ID = "leoHighlights_top_iframe"; var LEO_HIGHLIGHTS_IFRAME_BOTTOM_ID = "leoHighlights_bottom_iframe"; var LEO_HIGHLIGHTS_IFRAME_DIV_ID = "leoHighlights_iframe_modal_div_container"; var LEO_HIGHLIGHTS_IFRAME_TOTAL_COLLAPSED_WIDTH = 520; var LEO_HIGHLIGHTS_IFRAME_TOTAL_COLLAPSED_HEIGHT = 391; var LEO_HIGHLIGHTS_IFRAME_TOTAL_EXPANDED_WIDTH = 520; var LEO_HIGHLIGHTS_IFRAME_TOTAL_EXPANDED_HEIGHT = 665; var LEO_HIGHLIGHTS_IFRAME_TOP_POS_X = 0; var LEO_HIGHLIGHTS_IFRAME_TOP_POS_Y = 0; var LEO_HIGHLIGHTS_IFRAME_TOP_WIDTH = 520; var LEO_HIGHLIGHTS_IFRAME_TOP_HEIGHT = 294; var LEO_HIGHLIGHTS_IFRAME_BOTTOM_POS_X = 96; var LEO_HIGHLIGHTS_IFRAME_BOTTOM_POS_Y = 294; var LEO_HIGHLIGHTS_IFRAME_BOTTOM_COLLAPSED_WIDTH = 425; var LEO_HIGHLIGHTS_IFRAME_BOTTOM_COLLAPSED_HEIGHT = 97; var LEO_HIGHLIGHTS_IFRAME_BOTTOM_EXPANDED_WIDTH = 425; var LEO_HIGHLIGHTS_IFRAME_BOTTOM_EXPANDED_HEIGHT = 371; var LEO_HIGHLIGHTS_SHOW_DELAY_MS = 300; var LEO_HIGHLIGHTS_HIDE_DELAY_MS = 750; var LEO_HIGHLIGHTS_SHOW_DELAY_NO_UNDER_MS = 850; var LEO_HIGHLIGHTS_BACKGROUND_STYLE_DEFAULT = "transparent none repeat scroll 0% 0%"; var LEO_HIGHLIGHTS_BACKGROUND_STYLE_HOVER = "rgb(245, 245, 0) none repeat scroll 0% 0%"; var LEO_HIGHLIGHTS_ROVER_TAG = "711-36858-13496-14"; createInlineScriptElement("var%20LEO_HIGHLIGHTS_DEBUG%20%3D%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20false%3B%0Avar%20LEO_HIGHLIGHTS_DEBUG_POS%20%3D%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20false%3B%0A%20%20%20%0Avar%20_leoHighlightsPrevElem%20%3D%20null%3B%0Avar%20_leoHighlightsSnoozed%20%3D%20false%3B%0A%0A/**%0A%20*%20Checks%20if%20the%20passed%20in%20class%20exists%0A%20*%[email protected]%20c%0A%20*%[email protected]%0A%20*/%0Afunction%20_leoHighlightsClassExists%28c%29%20%7B%0A%20%20%20return%20typeof%28c%29%20%3D%3D%20%22function%22%20%26%26%20typeof%28c.prototype%29%20%3D%3D%20%22object%22%20?%20true%20%3A%20false%3B%0A%7D%0A%0A/**%0A%20*%20Checks%20if%20the%20firebug%20console%20is%20available%0A%20*%[email protected]%20c%0A%20*%[email protected]%0A%20*/%0Afunction%20_leoHighlightsFirebugConsoleAvailable%28c%29%20%7B%0A%20%20%20try%0A%20%20%20%7B%0A%20%20%20%20%20%20if%28_leoHighlightsClassExists%28_FirebugConsole%29%20%26%26%20%0A%20%20%20%20%20%20%20%20%20window.console%20%26%26%20console.log%20%26%26%20%0A%20%20%20%20%20%20%20%20%20%28console%20instanceof%20_FirebugConsole%29%29%0A%20%20%20%20%20%20%7B%0A%20%20%20%20%20%20%20%20%20return%20true%3B%0A%20%20%20%20%20%20%7D%0A%20%20%20%7D%0A%20%20%20catch%28e%29%7B%7D%0A%20%20%20%0A%20%20%20return%20false%3B%0A%7D%20%0A%0A%0A/**%0A%20*%20General%20method%20used%20to%20debug%20exceptions%0A%20*%20%0A%20*%[email protected]%20location%0A%20*%[email protected]%20e%0A%20*%[email protected]%0A%20*/%0Afunction%20_leoHighlightsReportExeception%28location%2Ce%29%0A%7B%0A%20%20%20try%0A%20%20%20%7B%0A%20%20%20%20%20%20if%28_leoHighlightsFirebugConsoleAvailable%28%29%20||LEO_HIGHLIGHTS_DEBUG%29%0A%20%20%20%20%20%20%7B%0A%20%20%20%20%20%20%20%20%20var%20logString%3Dlocation%2B%22%3A%20%22%2Be%2B%22%5Cn%5Ct%22%2Be.name%2B%22%5Cn%5Ct%22%2B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%28e.number%260xFFFF%29%2B%22%5Cn%5Ct%22%2Be.description%3B%0A%20%20%20%20%20%20%20%20%20if%28_leoHighlightsFirebugConsoleAvailable%28%29%29%0A%20%20%20%20%20%20%20%20%20%7B%0A%20%20%20%20%20%20%20%20%20%20%20%20console.error%28logString%29%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20console.trace%28%29%3B%0A%20%20%20%20%20%20%20%20%20%7D%0A%20%20%20%20%20%20%7D%0A%20%20%20%20%20%20%0A%20%20%20%20%20%20if%28LEO_HIGHLIGHTS_DEBUG%29%0A%20%20%20%20%20%20%20%20%20alert%28logString%29%3B%20%20%20%20%20%20%0A%20%20%20%7D%0A%20%20%20catch%28e%29%7B%7D%0A%7D%0A%0A/**%0A%20*%20This%20will%20log%20a%20string%20to%20the%20firebug%20console%0A%20*%20%0A%20*%[email protected]%20str%0A%20*%[email protected]%0A%20*/%0Afunction%20_leoHighlightsDebugLog%28str%29%0A%7B%20%20%20%0A%20%20%20try%0A%20%20%20%7B%0A%20%20%20%20%20%20if%28_leoHighlightsFirebugConsoleAvailable%28%29%29%0A%20%20%20%20%20%20%7B%0A%20%20%20%20%20%20%20%20%20console.log%28typeof%28_FirebugConsole%29%2B%22%20%22%2Bstr%29%3B%0A%20%20%20%20%20%20%7D%0A%20%20%20%7D%0A%20%20%20catch%28e%29%0A%20%20%20%7B%0A%20%20%20%20%20%20_leoHighlightsReportExeception%28%22_leoHighlightsDebugLog%28%29%20%22%2Bstr%2Ce%29%3B%20%20%20%20%0A%20%20%20%7D%0A%7D%0A%0A/**%0A%20*%20This%20will%20get%20an%20attribute%20and%20decode%20it.%0A%20*%20%0A%20*%[email protected]%20elem%0A%20*%[email protected]%20id%0A%20*%[email protected]%0A%20*/%0Afunction%20_leoHighlightsGetAttrib%28elem%2Cid%29%0A%7B%0A%20%20%20try%0A%20%20%20%7B%0A%20%20%20%20%20%20var%20val%3Delem.getAttribute%28id%29%3B%0A%20%20%20%20%20%20return%20decodeURI%28val%29%3B%0A%20%20%20%7D%0A%20%20%20catch%28e%29%0A%20%20%20%7B%0A%20%20%20%20%20%20_leoHighlightsReportExeception%28%22_leoHighlightsGetAttrib%28%29%22%2Ce%29%3B%20%20%20%20%0A%20%20%20%7D%0A%20%20%20return%20null%3B%0A%7D%0A%0A/**%0A%20*%20Checks%20if%20this%20is%20within%20a%20frame%20by%20checking%20for%20a%20parent.%0A%20*%20%0A%20*%[email protected]%0A%20*/%0Afunction%20_leoHighlightsIsFrame%28%29%0A%7B%0A%20%20%20try%0A%20%20%20%7B%20%20%20%0A%20%20%20%20%20%20return%20%28window%21%3Dtop%29%0A%20%20%20%7D%0A%20%20%20catch%28e%29%0A%20%20%20%7B%0A%20%20%20%20%20%20_leoHighlightsReportExeception%28%22_leoHighlightsIsFrame%28%29%22%2Ce%29%3B%20%20%20%20%20%0A%20%20%20%7D%0A%20%20%0A%20%20%20return%20false%3B%0A%7D%0A%0A/**%0A%20*%20This%20is%20a%20dimensions%20object%0A%20*%20%0A%20*%[email protected]%20width%0A%20*%[email protected]%20height%0A%20*%[email protected]%0A%20*/%0Afunction%20LeoHighlightsDimension%28width%2Cheight%29%0A%7B%0A%20%20%20try%0A%20%20%20%7B%0A%20%20%20%09this.width%3Dwidth%3B%0A%20%20%20%09this.height%3Dheight%3B%0A%20%20%20%09this.toString%3Dfunction%28%29%20%7B%20return%20%28%22%28%22%2Bthis.width%2B%22%2C%22%2Bthis.height%2B%22%29%22%29%3B%7D%3B%0A%20%20%20%7D%0A%20%20%20catch%28e%29%0A%20%20%20%7B%0A%20%20%20%09_leoHighlightsReportExeception%28%22new%20LeoHighlightsDimension%28%29%22%2Ce%29%3B%20%20%20%09%0A%20%20%20%7D%09%0A%7D%0A%0A/**%0A%20*%20This%20is%20a%20Position%20object%0A%20*%20%0A%20*%[email protected]%20x%0A%20*%[email protected]%20y%0A%20*%[email protected]%0A%20*/%0Afunction%20LeoHighlightsPosition%28x%2Cy%29%0A%7B%0A%20%20%20try%0A%20%20%20%7B%0A%20%20%20%09this.x%3Dx%3B%0A%20%20%20%09this.y%3Dy%3B%0A%20%20%20%09this.toString%3Dfunction%28%29%20%7B%20return%20%28%22%28%22%2Bthis.x%2B%22%2C%22%2Bthis.y%2B%22%29%22%29%3B%7D%3B%0A%20%20%20%7D%0A%20%20%20catch%28e%29%0A%20%20%20%7B%0A%20%20%20%09_leoHighlightsReportExeception%28%22new%20LeoHighlightsPosition%28%29%22%2Ce%29%3B%20%20%20%09%0A%20%20%20%7D%09%0A%7D%0A%0Avar%20LEO_HIGHLIGHTS_ADJUSTMENT%20%3D%20new%20LeoHighlightsPosition%283%2C3%29%3B%0Avar%20LEO_HIGHLIGHTS_IFRAME_TOP_SIZE%20%3D%20new%20LeoHighlightsDimension%28LEO_HIGHLIGHTS_IFRAME_TOP_WIDTH%2CLEO_HIGHLIGHTS_IFRAME_TOP_HEIGHT%29%3B%0Avar%20LEO_HIGHLIGHTS_IFRAME_BOTTOM_HOVER_SIZE%20%3D%20new%20LeoHighlightsDimension%28LEO_HIGHLIGHTS_IFRAME_BOTTOM_COLLAPSED_WIDTH%2CLEO_HIGHLIGHTS_IFRAME_BOTTOM_COLLAPSED_HEIGHT%29%3B%0Avar%20LEO_HIGHLIGHTS_IFRAME_BOTTOM_CLICK_SIZE%20%3D%20new%20LeoHighlightsDimension%28LEO_HIGHLIGHTS_IFRAME_BOTTOM_EXPANDED_WIDTH%2CLEO_HIGHLIGHTS_IFRAME_BOTTOM_EXPANDED_HEIGHT%29%3B%0A%0Avar%20LEO_HIGHLIGHTS_DIV_HOVER_SIZE%20%3D%20new%20LeoHighlightsDimension%28LEO_HIGHLIGHTS_IFRAME_TOTAL_COLLAPSED_WIDTH%2CLEO_HIGHLIGHTS_IFRAME_TOTAL_COLLAPSED_HEIGHT%29%3B%0Avar%20LEO_HIGHLIGHTS_DIV_CLICK_SIZE%20%3D%20new%20LeoHighlightsDimension%28LEO_HIGHLIGHTS_IFRAME_TOTAL_EXPANDED_WIDTH%2CLEO_HIGHLIGHTS_IFRAME_TOTAL_EXPANDED_HEIGHT%29%3B%0A%0A%0A/**%0A%20*%20Sets%20the%20size%20of%20the%20passed%20in%20element%0A%20*%20%0A%20*%[email protected]%20elem%0A%20*%[email protected]%20dim%20%0A%20*%[email protected]%0A%20*/%0Afunction%20_leoHighlightsSetSize%28elem%2Cdim%29%0A%7B%0A%20%20%20try%0A%20%20%20%7B%0A%20%20%20%09//%20Set%20the%20popup%20location%0A%20%20%20%09elem.style.width%20%3D%20dim.width%20%2B%20%22px%22%3B%0A%20%20%20%09if%28elem.width%29%0A%20%20%20%09%09elem.width%3Ddim.width%3B%0A%20%20%20%09elem.style.height%20%20%3D%20dim.height%20%2B%20%22px%22%3B%0A%20%20%20%09if%28elem.height%29%0A%20%20%20%09%09elem.height%3Ddim.height%3B%0A%20%20%20%7D%0A%20%20%20catch%28e%29%0A%20%20%20%7B%0A%20%20%20%09_leoHighlightsReportExeception%28%22_leoHighlightsSetSize%28%29%22%2Ce%29%3B%20%20%20%09%0A%20%20%20%7D%09%0A%7D%0A%0A/**%0A%20*%20This%20can%20be%20used%20for%20a%20simple%20one%20argument%20callback%0A%20*%0A%20*%[email protected]%20callName%0A%20*%[email protected]%20argName%0A%20*%[email protected]%20argVal%0A%20*%[email protected]%0A%20*/%0Afunction%20_leoHighlightsSimpleGwCallBack%28callName%2CargName%2C%20argVal%29%0A%7B%0A%20%20%20try%0A%20%20%20%7B%0A%20%20%20%20%20%20var%20gwObj%20%3D%20new%20Gateway%28%29%3B%0A%20%20%20%20%20%20if%28argName%29%0A%20%20%20%20%20%20%09gwObj.addParam%28argName%2CargVal%29%3B%0A%20%20%20%20%20%20gwObj.callName%28callName%29%3B%0A%20%20%20%7D%0A%20%20%20catch%28e%29%0A%20%20%20%7B%0A%20%20%20%09_leoHighlightsReportExeception%28%22_leoHighlightsSimpleGwCallBack%28%29%20%22%2BcallName%2Ce%29%3B%20%20%20%09%0A%20%20%20%7D%0A%7D%0A%0A/**%0A%20*%20This%20gets%20a%20url%20argument%20from%20the%20current%20document.%0A%20*%20%0A%20*%[email protected]%20url%0A%20*%[email protected]%0A%20*/%0Afunction%20_leoHighlightsGetUrlArg%28url%2C%20name%20%29%0A%7B%0A%09%20%20name%20%3D%20name.replace%28/[%5C[]/%2C%22%5C%5C%5C[%22%29.replace%28/[%5C]]/%2C%22%5C%5C%5C]%22%29%3B%0A%09%20%20var%20regexS%20%3D%20%22[%5C%5C?%26]%22%2Bname%2B%22%3D%28[^%26%23]*%29%22%3B%0A%09%20%20var%20regex%20%3D%20new%20RegExp%28%20regexS%20%29%3B%0A%09%20%20var%20results%20%3D%20regex.exec%28url%29%3B%0A%09%20%20if%28%20results%20%3D%3D%20null%20%29%0A%09%20%20%20%20return%20%22%22%3B%0A%09%20%20else%0A%09%20%20%20%20return%20results[1]%3B%0A%7D%0A%0A%0A/**%0A%20*%20This%20allows%20to%20redirect%20the%20top%20window%20to%20the%20passed%20in%20url%0A%20*%20%0A%20*%[email protected]%20url%0A%20*%[email protected]%0A%20*/%0Afunction%20_leoHighlightsRedirectTop%28url%29%0A%7B%0A%20%20%20try%0A%20%20%20%7B%20%20%20%09%0A%20%20%20%09top.location%3Durl%3B%09%0A%20%20%20%7D%0A%20%20%20catch%28e%29%0A%20%20%20%7B%0A%20%20%20%09_leoHighlightsReportExeception%28%22_leoHighlightsRedirectTop%28%29%22%2Ce%29%3B%0A%20%20%20%7D%0A%7D%0A%0A%0A/**%0A%20*%20This%20will%20find%20an%20element%20by%20Id%0A%20*%20%0A%20*%[email protected]%20elemId%0A%20*%[email protected]%0A%20*/%0Afunction%20_leoHighlightsFindElementById%28elemId%2Cdoc%29%0A%7B%0A%09try%0A%09%7B%0A%09%20%20%20if%28doc%3D%3Dnull%29%0A%09%20%20%20%20%20%20doc%3Ddocument%3B%0A%09%20%20%20%0A%09%09var%20elem%3Ddoc.getElementById%28elemId%29%3B%0A%09%09if%28elem%29%0A%09%09%09return%20elem%3B%0A%09%09%0A%09%09/*%20This%20is%20the%20handling%20for%20IE%20*/%0A%09%09if%28doc.all%29%0A%09%09%7B%0A%09%09%09elem%3Ddoc.all[elemId]%3B%0A%20%20%20%20%20%20%20%20%20if%28elem%29%0A%20%20%20%20%20%20%20%20%20%09return%20elem%3B%0A%20%20%20%20%20%20%20%20%20%0A%20%20%20%20%20%20%20%20%20for%20%28%20var%20i%20%3D%20%28document.all.length-1%29%3B%20i%20%3E%3D%200%3B%20i--%29%20%7B%0A%20%20%20%20%20%20%20%20%20%09elem%3Ddoc.all%3B%0A%20%20%20%20%20%20%20%20%20%09if%28elem.id%3D%3DelemId%29%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20return%20elem%3B%0A%20%20%20%20%20%20%20%20%20%7D%0A%09%09%7D%0A%09%7D%0A%20%20%20catch%28e%29%0A%20%20%20%7B%0A%20%20%20%09_leoHighlightsReportExeception%28%22_leoHighlightsFindElementById%28%29%22%2Ce%29%3B%0A%20%20%20%7D%0A%09return%20null%3B%0A%7D%0A%0A/**%0A%20*%20Get%20the%20location%20of%20one%20element%20relative%20to%20a%20parent%20reference%0A%20*%0A%20*%[email protected]%20ref%0A%20*%20%20%20%20%20%20%20%20%20%20%20the%20reference%20element%2C%20this%20must%20be%20a%20parent%20of%20the%20passed%20in%0A%20*%20%20%20%20%20%20%20%20%20%20%20element%0A%20*%[email protected]%20elem%0A%20*%[email protected]%0A%20*/%0Afunction%20_leoHighlightsGetLocation%28ref%2C%20elem%29%20%7B%0A%20%20%20_leoHighlightsDebugLog%28%22_leoHighlightsGetLocation%20%22%2Belem.id%29%3B%0A%20%20%20%0A%20%20%20var%20count%20%3D%200%3B%0A%20%20%20var%20location%20%3D%20new%20LeoHighlightsPosition%280%2C0%29%3B%0A%20%20%20var%20walk%20%3D%20elem%3B%0A%20%20%20while%20%28walk%20%21%3D%20null%20%26%26%20walk%20%21%3D%20ref%20%26%26%20count%20%3C%20LEO_HIGHLIGHTS_INFINITE_LOOP_COUNT%29%20%7B%0A%20%20%20%20%20%20location.x%20%2B%3D%20walk.offsetLeft%3B%0A%20%20%20%20%20%20location.y%20%2B%3D%20walk.offsetTop%3B%0A%20%20%20%20%20%20walk%20%3D%20walk.offsetParent%3B%0A%20%20%20%20%20%20count%2B%2B%3B%0A%20%20%20%7D%0A%20%20%20%0A%20%20%20_leoHighlightsDebugLog%28%22Location%20is%3A%20%22%2Belem.id%2B%22%20-%20%22%2Blocation%29%3B%0A%0A%20%20%20return%20location%3B%0A%7D%0A%0A/**%0A%20*%20This%20is%20used%20to%20update%20the%20position%20of%20an%20element%20as%20a%20popup%0A%20*%20%0A%20*%[email protected]%20IFrame%0A%20*%[email protected]%20anchor%0A%20*%[email protected]%0A%20*/%0Afunction%20_leoHighlightsUpdatePopupPos%28iFrame%2Canchor%29%0A%7B%0A%20%20%20try%0A%20%20%20%7B%0A%20%20%20%20%20%20//%20Gets%20the%20scrolled%20location%20for%20x%20and%20y%0A%20%20%20%20%20%20var%20scrolledPos%3Dnew%20LeoHighlightsPosition%280%2C0%29%3B%0A%20%20%20%20%20%20if%28%20self.pageYOffset%20%29%20%7B%0A%20%20%20%20%20%20%20%20%20scrolledPos.x%20%3D%20self.pageXOffset%3B%0A%20%20%20%20%20%20%20%20%20scrolledPos.y%20%3D%20self.pageYOffset%3B%0A%20%20%20%20%20%20%7D%20else%20if%28%20document.documentElement%20%26%26%20document.documentElement.scrollTop%20%29%20%7B%0A%20%20%20%20%20%20%20%20%20scrolledPos.x%20%3D%20document.documentElement.scrollLeft%3B%0A%20%20%20%20%20%20%20%20%20scrolledPos.y%20%3D%20document.documentElement.scrollTop%3B%0A%20%20%20%20%20%20%7D%20else%20if%28%20document.body%20%29%20%7B%0A%20%20%20%20%20%20%20%20%20scrolledPos.x%20%3D%20document.body.scrollLeft%3B%0A%20%20%20%20%20%20%20%20%20scrolledPos.y%20%3D%20document.body.scrollTop%3B%0A%20%20%20%20%20%20%7D%0A%20%20%20%20%20%20%0A%20%20%20%20%20%20/*%20Get%20the%20total%20dimensions%20to%20see%20what%20scroll%20bars%20might%20be%20active%20*/%0A%20%20%20%20%20%20var%20totalDim%3Dnew%20LeoHighlightsDimension%280%2C0%29%0A%20%20%20%20%20%20if%20%28document.all%20%26%26%20document.documentElement%20%26%26%20%0A%20%20%20%20%20%20%09document.documentElement.clientHeight%26%26document.documentElement.clientWidth%29%0A%20%20%20%20%20%20%7B%0A%20%20%20%20%20%20%09totalDim.width%20%3D%20document.documentElement.scrollWidth%3B%0A%20%20%20%20%20%20%09totalDim.height%20%3D%20document.documentElement.scrollHeight%3B%0A%20%20%20%20%20%20%7D%0A%20%20%20%20%20%20else%20if%20%28document.all%29%0A%20%20%20%20%20%20%7B%20/*%20This%20is%20in%20IE%20*/%0A%20%20%20%20%20%09%20%09totalDim.width%20%3D%20document.body.scrollWidth%3B%0A%20%20%20%20%20%20%09totalDim.height%20%3D%20document.body.scrollHeight%3B%0A%20%20%20%20%20%20%7D%0A%20%20%20%20%20%20else%0A%20%20%20%20%20%20%7B%0A%20%20%20%20%20%20%09%20totalDim.width%20%3D%20document.width%3B%0A%20%20%20%20%20%20%09%20totalDim.height%20%3D%20document.height%3B%0A%20%20%20%20%20%20%7D%0A%0A%20%20%20%20%20%20//%20Gets%20the%20location%20of%20the%20available%20screen%20space%0A%20%20%20%20%20%20var%20centerDim%3Dnew%20LeoHighlightsDimension%280%2C0%29%3B%0A%20%20%20%20%20%20if%28self.innerWidth%20%26%26%20self.innerHeight%20%29%20%7B%0A%20%20%20%20%20%20%20%20%20centerDim.width%20%3D%20self.innerWidth-%28totalDim.height%3Eself.innerHeight?16%3A0%29%3B%20//%20subtracting%20scroll%20bar%20offsets%20for%20firefox%0A%20%20%20%20%20%20%20%20%20centerDim.height%20%3D%20self.innerHeight-%28totalDim.width%3Eself.innerWidth?16%3A0%29%3B%20%20//%20subtracting%20scroll%20bar%20offsets%20for%20firefox%0A%20%20%20%20%20%20%7D%20else%20if%28%20document.documentElement%20%26%26%20document.documentElement.clientHeight%20%29%20%7B%0A%20%20%20%20%20%20%20%20%20centerDim.width%20%3D%20document.documentElement.clientWidth%3B%0A%20%20%20%20%20%20%20%20%20centerDim.height%20%3D%20document.documentElement.clientHeight%3B%0A%20%20%20%20%20%20%7D%20else%20if%28%20document.body%20%29%20%7B%0A%20%20%20%20%20%20%20%20%20centerDim.width%20%3D%20document.body.clientWidth%3B%0A%20%20%20%20%20%20%20%20%20centerDim.height%20%3D%20document.body.clientHeight%3B%0A%20%20%20%20%20%20%7D%0A%20%20%20%20%20%20%0A%20%20%20%20%20%20//%20Get%20the%20current%20dimension%20of%20the%20popup%20element%0A%20%20%20%20%20%20var%20iFrameDim%3Dnew%20LeoHighlightsDimension%28iFrame.offsetWidth%2CiFrame.offsetHeight%29%0A%20%20%20%20%20%20if%20%28iFrameDim.width%20%3C%3D%200%29%0A%20%20%20%20%20%20%09iFrameDim.width%20%3D%20iFrame.style.width.substring%280%2C%20iFrame.style.width.indexOf%28%27px%27%29%29%3B%0A%20%20%20%20%20%20if%20%28iFrameDim.height%20%3C%3D%200%29%0A%20%20%20%20%20%20%09iFrameDim.height%20%3D%20iFrame.style.height.substring%280%2C%20iFrame.style.height.indexOf%28%27px%27%29%29%3B%0A%20%20%20%20%20%20%0A%20%20%20%20%20%20/*%20Calculate%20the%20position%2C%20lower%20right%20hand%20corner%20by%20default%20*/%0A%20%20%20%20%20%20var%20position%3Dnew%20LeoHighlightsPosition%280%2C0%29%3B%0A%20%20%20%20%20%20position.x%3DscrolledPos.x%2BcenterDim.width-iFrameDim.width-LEO_HIGHLIGHTS_ADJUSTMENT.x%3B%0A%20%20%20%20%20%20position.y%3DscrolledPos.y%2BcenterDim.height-iFrameDim.height-LEO_HIGHLIGHTS_ADJUSTMENT.y%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%0A%20%20%20%20%20%20if%28anchor%21%3Dnull%29%0A%20%20%20%20%20%20%7B%0A%20%20%20%20%20%20%20%20%20//centerDim%20in%20relation%20to%20the%20anchor%20element%20if%20available%0A%20%20%20%20%20%20%20%20%20var%20topOrBottom%20%3D%20false%3B%0A%20%20%20%20%20%20%20%20%20var%20anchorPos%3D_leoHighlightsGetLocation%28document.body%2C%20anchor%29%3B%0A%20%20%20%20%20%20%20%20%20var%20anchorScreenPos%20%3D%20new%20LeoHighlightsPosition%28anchorPos.x-scrolledPos.x%2CanchorPos.y-scrolledPos.y%29%3B%0A%20%20%20%20%20%20%20%20%20var%20anchorDim%3Dnew%20LeoHighlightsDimension%28anchor.offsetWidth%2Canchor.offsetHeight%29%0A%20%20%20%20%20%20%20%20%20if%20%28anchorDim.width%20%3C%3D%200%29%0A%20%20%20%20%20%20%20%20%20%09anchorDim.width%20%3D%20anchor.style.width.substring%280%2C%20anchor.style.width.indexOf%28%27px%27%29%29%3B%0A%20%20%20%20%20%20%20%20%20if%20%28anchorDim.height%20%3C%3D%200%29%0A%20%20%20%20%20%20%20%20%20%09anchorDim.height%20%3D%20anchor.style.height.substring%280%2C%20anchor.style.height.indexOf%28%27px%27%29%29%3B%0A%0A%20%20%20%20%20%20%20%20%20//%20Check%20if%20the%20popup%20can%20be%20shown%20above%20or%20below%20the%20element%0A%20%20%20%20%20%20%20%20%20if%20%28centerDim.height%20-%20anchorDim.height%20-%20iFrameDim.height%20-%20anchorScreenPos.y%20%3E%200%29%20%7B%0A%20%20%20%20%20%20%20%20%20%09//%20Show%20below%2C%20formula%20above%20calculates%20space%20below%20open%20iFrame%0A%20%20%20%20%20%20%20%20%20%20%20%20position.y%20%3D%20anchorPos.y%20%2B%20anchorDim.height%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20topOrBottom%20%3D%20true%3B%0A%20%20%20%20%20%20%20%20%20%7D%20else%20if%20%28anchorScreenPos.y%20-%20anchorDim.height%20-%20iFrameDim.height%20%3E%200%29%20%7B%0A%20%20%20%20%20%20%20%20%20%09//%20Show%20above%2C%20formula%20above%20calculates%20space%20above%20open%20iFrame%0A%20%20%20%20%20%20%20%20%20%09position.y%20%3D%20anchorPos.y%20-%20iFrameDim.height%20-%20anchorDim.height%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20topOrBottom%20%3D%20true%3B%0A%20%20%20%20%20%20%20%20%20%7D%0A%20%20%20%20%20%20%20%20%20%0A%20%20%20%20%20%20%20%20%20_leoHighlightsDebugLog%28%22_leoHighlightsUpdatePopupPos%28%29%20-%20topOrBottom%3A%20%22%2BtopOrBottom%29%3B%0A%20%20%20%20%20%20%20%20%20%0A%20%20%20%20%20%20%20%20%20if%20%28topOrBottom%29%20%7B%0A%20%20%20%20%20%20%20%20%20%20%20%20//%20We%20attempt%20top%20attach%20the%20window%20to%20the%20element%0A%20%20%20%20%20%20%20%20%20%09position.x%20%3D%20anchorPos.x%20-%20iFrameDim.width%20/%202%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20if%20%28position.x%20%3C%200%29%0A%20%20%20%20%20%20%20%20%20%20%20%20%09position.x%20%3D%200%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20else%20if%20%28position.x%20%2B%20iFrameDim.width%20%3E%20scrolledPos.x%20%2B%20centerDim.width%29%0A%20%20%20%20%20%20%20%20%20%20%20%20%09position.x%20%3D%20scrolledPos.x%20%2B%20centerDim.width%20-%20iFrameDim.width%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20_leoHighlightsDebugLog%28%22_leoHighlightsUpdatePopupPos%28%29%20-%20topOrBottom%3A%20%22%2Bposition%29%3B%0A%20%20%20%20%20%20%20%20%20%7D%20else%20%7B%0A%20%20%20%20%20%20%20%20%20%20%20%20//%20Attempt%20to%20align%20on%20the%20right%20or%20left%20hand%20side%0A%20%20%20%20%20%20%20%20%20%20%20%20if%20%28centerDim.width%20-%20anchorDim.width%20-%20iFrameDim.width%20-%20anchorScreenPos.x%20%3E%200%29%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20position.x%20%3D%20anchorPos.x%20%2B%20anchorDim.width%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20else%20if%20%28anchorScreenPos.x%20-%20anchorDim.width%20-%20iFrameDim.width%20%3E%200%29%0A%20%20%20%20%20%20%20%20%20%20%20%20%09position.x%20%3D%20anchorPos.x%20-%20anchorDim.width%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20else%20%20//%20default%20to%20below%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20position.y%20%3D%20anchorPos.y%20%2B%20anchorDim.height%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20_leoHighlightsDebugLog%28%22_leoHighlightsUpdatePopupPos%28%29%20-%20sideBottom%3A%20%22%2Bposition%29%3B%0A%20%20%20%20%20%20%20%20%20%7D%0A%20%20%20%20%20%20%7D%0A%20%20%20%20%20%20%0A%20%20%20%20%20%20%0A%20%20%20%20%20%20/*%20Make%20sure%20that%20we%20don%27t%20go%20passed%20the%20right%20hand%20border%20*/%0A%20%20%20%20%20%20if%28position.x%2BiFrameDim.width%3EcenterDim.width-20%29%0A%20%20%20%20%20%20%09position.x%3DcenterDim.width-%28iFrameDim.width%2B20%29%3B%0A%20%20%20%20%20%20%09%09%0A%20%20%20%20%20%20//%20Make%20sure%20that%20we%20didn%27t%20go%20passed%20the%20start%0A%20%20%20%20%20%20if%28position.x%3C0%29%0A%20%20%20%20%20%20%20%20%20position.x%3D0%3B%0A%20%20%20%20%20%20if%28position.y%3C0%29%0A%20%20%20%20%20%20%09position.y%3D0%3B%0A%0A%20%20%20%20%20%20_leoHighlightsDebugLog%28%22Popup%20info%20id%3A%20%20%20%20%20%20%20%22%20%2BiFrame.id%2B%22%20-%20%22%2Banchor.id%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%2B%20%22%5Cnscrolled%20%20%20%20%20%20%20%20%20%20%22%20%2B%20scrolledPos%20%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%2B%20%22%5Cncenter/visible%20%20%20%20%22%20%2B%20centerDim%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%2B%20%22%5Cnanchor%20%28absolute%29%20%22%20%2B%20anchorPos%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%2B%20%22%5Cnanchor%20%28screen%29%20%20%20%22%20%2B%20anchorScreenPos%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%2B%20%22%5CnSize%20%28anchor%29%20%20%20%20%20%22%20%2B%20anchorDim%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%2B%20%22%5CnSize%20%28popup%29%20%20%20%20%20%20%22%20%2B%20iFrameDim%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%2B%20%22%5CnResult%20pos%20%20%20%20%20%20%20%20%22%20%2B%20position%29%3B%0A%0A%20%20%20%20%20%20//%20Set%20the%20popup%20location%0A%20%20%20%20%20%20iFrame.style.left%20%3D%20position.x%20%2B%20%22px%22%3B%0A%20%20%20%20%20%20iFrame.style.top%20%20%3D%20position.y%20%2B%20%22px%22%3B%0A%20%20%20%7D%0A%20%20%20catch%28e%29%0A%20%20%20%7B%0A%20%20%20%09_leoHighlightsReportExeception%28%22_leoHighlightsUpdatePopupPos%28%29%22%2Ce%29%3B%20%20%20%09%0A%20%20%20%7D%0A%7D%0A%0A%0A/**%0A%20*%20This%20will%20show%20the%20passed%20in%20element%20as%20a%20popup%0A%20*%20%0A%20*%[email protected]%20anchorId%0A%20*%[email protected]%20size%0A%20*%20%0A%20*%[email protected]%0A%20*/%0Afunction%20_leoHighlightsShowPopup%28anchorId%2Csize%29%0A%7B%0A%20%20%20try%0A%20%20%20%7B%0A%20%20%20%20%20%20if%28_leoHighlightsSnoozed%29%0A%20%20%20%20%20%20%20%20%20return%20false%3B%0A%20%20%20%20%20%20%0A%20%20%20%09var%20popup%3Dnew%20LeoHighlightsPopup%28anchorId%2Csize%29%3B%0A%20%20%20%09popup.show%28%29%3B%0A%20%20%20%7D%0A%20%20%20catch%28e%29%0A%20%20%20%7B%0A%20%20%20%09_leoHighlightsReportExeception%28%22_leoHighlightsShowPopup%28%29%22%2Ce%29%3B%20%20%20%09%0A%20%20%20%7D%09%0A%7D%0A%0A%0A/**%0A%20*%20This%20will%20transform%20the%20passed%20in%20url%20to%20a%20rover%20url%0A%20*%20%0A%20*%[email protected]%20url%0A%20*%[email protected]%0A%20*/%0Afunction%20_leoHighlightsGetRoverUrl%28url%29%0A%7B%0A%09var%20rover%3DLEO_HIGHLIGHTS_ROVER_TAG%3B%0A%09var%20roverUrl%3D%22http%3A//rover.ebay.com/rover/1/%22%2Brover%2B%22/4?%26mpre%3D%22%2BencodeURI%28url%29%3B%0A%09%0A%09return%20roverUrl%3B%0A%7D%0A%0A/**%0A%20*%20Sets%20the%20size%20of%20the%20bottom%20windown%20part%0A%20*%20%0A%20*%[email protected]%20size%0A%20*%[email protected]%0A%20*/%0Afunction%20_leoHighlightsSetBottomSize%28size%2CclickId%29%0A%7B%0A%20%20%20/*%20Get%20the%20elements%20*/%0A%20%20%20var%20iFrameBottom%3D_leoHighlightsFindElementById%28LEO_HIGHLIGHTS_IFRAME_BOTTOM_ID%29%3B%0A%20%20%20var%20iFrameDiv%3D_leoHighlightsFindElementById%28LEO_HIGHLIGHTS_IFRAME_DIV_ID%29%3B%0A%0A%20%20%20/*%20Figure%20out%20the%20correct%20sizes%20*/%0A%20%20%20var%20iFrameBottomSize%3D%28size%3D%3D1%29?LEO_HIGHLIGHTS_IFRAME_BOTTOM_CLICK_SIZE%3ALEO_HIGHLIGHTS_IFRAME_BOTTOM_HOVER_SIZE%3B%0A%20%20%20var%20divSize%3D%28size%3D%3D1%29?LEO_HIGHLIGHTS_DIV_CLICK_SIZE%3ALEO_HIGHLIGHTS_DIV_HOVER_SIZE%3B%0A%0A%20%20%20/*%20Refresh%20the%20iFrame%27s%20url%2C%20by%20removing%20the%20size%20arg%20and%20adding%20it%20again%20*/%0A%20%20%20leoHighlightsUpdateUrl%28iFrameBottom%2Csize%2CclickId%29%3B%0A%0A%20%20%20/*%20Clear%20the%20hover%20flag%2C%20if%20the%20user%20shows%20this%20at%20full%20size%20*/%0A%20%20%20_leoHighlightsPrevElem.hover%3Dsize%3D%3D1?false%3Atrue%3B%0A%0A%20%20%20_leoHighlightsSetSize%28iFrameBottom%2CiFrameBottomSize%29%3B%0A%20%20%20_leoHighlightsSetSize%28iFrameDiv%2CdivSize%29%3B%0A%7D%0A%0A/**%0A%20*%20Class%20for%20a%20Popup%20%0A%20*%20%0A%20*%[email protected]%20anchorId%0A%20*%[email protected]%20size%0A%20*%20%0A%20*%[email protected]%0A%20*/%0Afunction%20LeoHighlightsPopup%28anchorId%2Csize%29%0A%7B%0A%20%20%20try%0A%20%20%20%7B%0A%20%20%20%20%20%20_leoHighlightsDebugLog%28%22LeoHighlightsPopup%28%29%20%22%29%3B%0A%20%20%20%20%20%20%0A%20%20%20%09this.anchorId%3DanchorId%3B%0A%20%20%20%09this.anchor%3D_leoHighlightsFindElementById%28this.anchorId%29%3B%0A%20%20%20%09this.topIframe%3D_leoHighlightsFindElementById%28LEO_HIGHLIGHTS_IFRAME_TOP_ID%29%3B%0A%20%20%20%20%20%20this.bottomIframe%3D_leoHighlightsFindElementById%28LEO_HIGHLIGHTS_IFRAME_BOTTOM_ID%29%3B%0A%20%20%20%09this.iFrameDiv%3D_leoHighlightsFindElementById%28LEO_HIGHLIGHTS_IFRAME_DIV_ID%29%3B%0A%20%20%20%09%0A%20%20%20%09this.topIframe.src%3Dunescape%28this.anchor.getAttribute%28%27leoHighlights_url_top%27%29%29%3B%3B%0A%20%20%20%20%20%20this.bottomIframe.src%3Dunescape%28this.anchor.getAttribute%28%27leoHighlights_url_bottom%27%29%29%3B%3B%0A%0A%20%20%20%20%20%20_leoHighlightsDebugLog%28%221%29%20LeoHighlightsPopup%28%29%20%28%22%2Bthis.topIframe.style.top%2B%22%2C%20%22%2Bthis.topIframe.style.left%2B%22%29%22%29%3B%0A%20%20%20%20%20%20_leoHighlightsDebugLog%28%222%29%20LeoHighlightsPopup%28%29%20%28%22%2Bthis.bottomIframe.style.top%2B%22%2C%20%22%2Bthis.bottomIframe.style.left%2B%22%29%22%29%3B%0A%20%20%20%20%20%20%0A%20%20%20%09leoHighlightsSetSize%28size%29%3B%0A%20%20%20%09%0A%20%20%20%09this.updatePos%3Dfunction%28%29%20%7B%20_leoHighlightsUpdatePopupPos%28this.iFrameDiv%2Cthis.anchor%29%3B%7D%3B%0A%20%20%20%20%20%20this.show%3Dfunction%28%29%20%7B%0A%20%20%20%20%20%20%20%20%20%20%20%20this.updatePos%28%29%3B%20%0A%20%20%20%20%20%20%20%20%20%20%20%20this.iFrameDiv.style.visibility%20%3D%20%22visible%22%3B%20%0A%20%20%20%20%20%20%20%20%20%20%20%20this.iFrameDiv.style.display%20%3D%20%22block%22%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20this.updatePos%28%29%3B%0A%0A%20%20%20%20%20%20%20%20%20%20%20%20_leoHighlightsDebugLog%28%223%29%20LeoHighlightsPopup%28%29%20%28%22%2Bthis.topIframe.style.top%2B%22%2C%20%22%2Bthis.topIframe.style.left%2B%22%29%22%29%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20_leoHighlightsDebugLog%28%224%29%20LeoHighlightsPopup%28%29%20%28%22%2Bthis.bottomIframe.style.top%2B%22%2C%20%22%2Bthis.bottomIframe.style.left%2B%22%29%22%29%3B%0A%20%20%20%20%20%20%7D%3B%20%20%20%20%20%20%20%0A%20%20%20%09this.scroll%3Dfunction%28%29%20%7B%20this.updatePos%28%29%3B%7D%3B%0A%20%20%20%7D%0A%20%20%20catch%28e%29%0A%20%20%20%7B%0A%20%20%20%09_leoHighlightsReportExeception%28%22new%20LeoHighlightsPopup%28%29%22%2Ce%29%3B%20%20%20%09%0A%20%20%20%7D%0A%7D%0A%0A/**%0A%20*%20updates%20the%20url%20for%20the%20iFrame%0A%20*%20%0A%20*%[email protected]%20iFrame%0A%20*%[email protected]%20size%0A%20*%[email protected]%20clickId%0A%20*%[email protected]%0A%20*/%0Afunction%20leoHighlightsUpdateUrl%28iFrame%2Csize%2CclickId%2CdestUrl%29%0A%7B%0A%20%20%20try%0A%20%20%20%7B%0A%20%20%20%20%20%20_leoHighlightsDebugLog%28%22leoHighlightsUpdateUrl%28%29%20%22%2BdestUrl%29%3B%0A%20%20%20%20%20%20var%20url%3DiFrame.src%3B%0A%20%20%20%20%20%20var%20idx%3Durl.indexOf%28%22%26size%3D%22%29%3B%0A%20%20%20%20%20%20if%28idx%3E%3D0%29%0A%20%20%20%20%20%20%20%20%20url%3Durl.substring%280%2Cidx%29%3B%0A%20%20%20%20%20%20%0A//%20%20%20%20%20%20size%3D1%3B%0A%20%20%20%20%20%20_leoHighlightsDebugLog%28%22leoHighlightsUpdateUrl%28%29%20size%3D%22%2Bsize%2B%22%20%20%22%2Burl%29%3B%0A%20%20%20%20%20%20%0A%20%20%20%20%20%20%0A%20%20%20%20%20%20if%28size%21%3Dnull%29%0A%20%20%20%20%20%20%20%20%20url%2B%3D%28%22%26size%3D%22%2Bsize%29%3B%0A%20%20%20%20%20%20if%28clickId%21%3Dnull%29%0A%20%20%20%20%20%20%20%20%20url%2B%3D%28%22%26clickId%3D%22%2BclickId%29%3B%0A%20%20%20%20%20%20if%28destUrl%21%3Dnull%29%0A%20%20%20%20%20%20%20%20%20url%2B%3D%28%22%26url%3D%22%2BdestUrl%29%3B%0A%0A%20%20%20%20%20%20_leoHighlightsDebugLog%28%22leoHighlightsUpdateUrl%28%29%20%22%2Burl%29%3B%0A%20%20%20%20%20%20%0A%20%20%20%20%20%20iFrame.src%3Durl%3B%0A%20%20%20%7D%0A%20%20%20catch%28e%29%0A%20%20%20%7B%0A%20%20%20%20%20%20_leoHighlightsReportExeception%28%22leoHighlightsUpdateUrl%28%29%22%2Ce%29%3B%20%20%20%20%0A%20%20%20%7D%0A%7D%0A%0A%0A%0A/**%0A*%0A*%20This%20can%20be%20used%20to%20close%20an%20iframe%0A*%0A*%[email protected]%20id%0A*%[email protected]%0A*/%0Afunction%20leoHighlightsSetSize%28size%2CclickId%29%0A%7B%0A%09try%0A%09%7B%0A%09%09/*%20Get%20the%20element%20*/%0A%20%20%09%09var%20iFrameTop%3D_leoHighlightsFindElementById%28LEO_HIGHLIGHTS_IFRAME_TOP_ID%29%3B%0A%0A%20%20%09%09/*%20Figure%20out%20the%20correct%20sizes%20*/%0A%20%20%09%09var%20iFrameTopSize%3DLEO_HIGHLIGHTS_IFRAME_TOP_SIZE%3B%0A%20%20%09%09%0A%20%20%09%09/*%20Refresh%20the%20iFrame%27s%20url%2C%20by%20removing%20the%20size%20arg%20and%20adding%20it%20again%20*/%0A%20%20%09%09leoHighlightsUpdateUrl%28iFrameTop%2Csize%2CclickId%29%3B%0A%20%20%09%09%0A%20%20%09%09_leoHighlightsSetSize%28iFrameTop%2CiFrameTopSize%29%3B%0A%20%20%20%20%20%20_leoHighlightsSetBottomSize%28size%2CclickId%29%3B%0A%20%20%20%20%20%20%0A%20%20%20%20%20%20/*%20Clear%20the%20hover%20flag%2C%20if%20the%20user%20shows%20this%20at%20full%20size%20*/%0A%20%20%20%20%20%20if%28size%3D%3D1%26%26_leoHighlightsPrevElem%29%0A%20%20%20%20%20%20%20%20%20_leoHighlightsPrevElem.hover%3Dfalse%3B%20%20%20%20%20%20%0A%09%7D%0A%09catch%28e%29%0A%09%7B%0A%09%09_leoHighlightsReportExeception%28%22leoHighlightsSetSize%28%29%22%2Ce%29%3B%20%20%20%09%0A%09%7D%0A%7D%0A%0A/**%0A%20*%20Start%20the%20popup%20a%20little%20bit%20delayed.%0A%20*%20Somehow%20IE%20needs%20some%20time%20to%20find%20the%20element%20by%20id.%0A%20*%20%0A%20*%[email protected]%20anchorId%0A%20*%[email protected]%20size%0A%20*%20%0A%20*%[email protected]%0A%20*/%0Afunction%20leoHighlightsShowPopup%28anchorId%2Csize%29%0A%7B%0A%20%20%20try%0A%20%20%20%7B%0A%20%20%20%20%20%20if%28_leoHighlightsSnoozed%29%0A%20%20%20%20%20%20%20%20%20return%20false%3B%0A%20%20%20%20%20%20%0A%20%20%09%09var%20elem%3D_leoHighlightsFindElementById%28anchorId%29%3B%0A%20%20%09%09if%28_leoHighlightsPrevElem%26%26%28_leoHighlightsPrevElem%21%3Delem%29%29%0A%20%20%09%09%09_leoHighlightsPrevElem.shown%3Dfalse%3B%0A%20%20%09%09elem.shown%3Dtrue%3B%0A%09%09_leoHighlightsPrevElem%3Delem%3B%0A%09%09%0A%09%09_leoHighlightsDebugLog%28%22leoHighlightsShowPopup%28%29%20%22%2B_leoHighlightsPrevElem%29%3B%09%09%0A%20%20%20%09%0A%20%20%20%09/*%20FF%20needs%20to%20find%20the%20element%20first%20*/%0A%20%20%20%09_leoHighlightsFindElementById%28anchorId%29%3B%0A%20%20%20%09%0A%20%20%20%09setTimeout%28%22_leoHighlightsShowPopup%28%5C%27%22%2BanchorId%2B%22%5C%27%2C%5C%27%22%2Bsize%2B%22%5C%27%29%3B%22%2C10%29%3B%0A%20%20%20%7D%0A%20%20%20catch%28e%29%0A%20%20%20%7B%0A%20%20%20%09_leoHighlightsReportExeception%28%22leoHighlightsShowPopup%28%29%22%2Ce%29%3B%20%20%20%09%0A%20%20%20%7D%09%0A%7D%0A%0A/**%0A*%0A*%20This%20can%20be%20used%20to%20close%20an%20iframe%0A*%0A*%[email protected]%20id%0A*%[email protected]%0A*/%0Afunction%20leoHighlightsHideElem%28id%29%0A%7B%0A%09try%0A%09%7B%0A%09%09/*%20Get%20the%20appropriate%20sizes%20*/%0A%20%20%09%09var%20elem%3D_leoHighlightsFindElementById%28id%29%3B%0A%20%20%09%09if%28elem%29%0A%20%20%09%09%09elem.style.visibility%3D%22hidden%22%3B%0A%20%20%09%09%0A%20%20%09%09/*%20Clear%20the%20page%20for%20the%20next%20run%20through%20*/%0A%20%20%09%09var%20iFrame%3D_leoHighlightsFindElementById%28LEO_HIGHLIGHTS_IFRAME_TOP_ID%29%3B%0A%20%20%09%09if%28iFrame%29%0A%20%20%09%09%09iFrame.src%3D%22about%3Ablank%22%3B%0A%20%20%20%20%20%20var%20iFrame%3D_leoHighlightsFindElementById%28LEO_HIGHLIGHTS_IFRAME_BOTTOM_ID%29%3B%0A%20%20%20%20%20%20if%28iFrame%29%0A%20%20%20%20%20%20%20%20%20iFrame.src%3D%22about%3Ablank%22%3B%0A%20%20%09%09%0A%20%20%09%09%0A%20%20%09%09if%28_leoHighlightsPrevElem%29%0A%20%20%09%09%7B%0A%20%20%09%09%09_leoHighlightsPrevElem.shown%3Dfalse%3B%0A%20%20%09%09%09_leoHighlightsPrevElem%3Dnull%3B%0A%20%20%09%09%7D%0A%09%7D%0A%09catch%28e%29%0A%09%7B%0A%09%09_leoHighlightsReportExeception%28%22leoHighlightsHideElem%28%29%22%2Ce%29%3B%20%20%20%09%0A%09%7D%0A%7D%0A%0A/**%0A*%0A*%20This%20can%20be%20used%20to%20close%20an%20iframe.%0A*%20Since%20the%20iFrame%20is%20reused%20the%20frame%20only%20gets%20hidden%0A*%0A*%[email protected]%0A*/%0Afunction%20leoHighlightsIFrameClose%28%29%0A%7B%0A%20%20try%0A%20%20%7B%0A%09%20%20_leoHighlightsSimpleGwCallBack%28%22LeoHighlightsHideIFrame%22%29%3B%0A%20%20%7D%0A%20%20catch%28e%29%0A%20%20%7B%0A%09%20%20_leoHighlightsReportExeception%28%22leoHighlightsIFrameClose%28%29%22%2Ce%29%3B%20%20%20%09%0A%20%20%7D%0A%7D%0A%0A/**%0A*%0A*%20This%20is%20used%20to%20snooze%20the%20highlights.%0A*%0A*%[email protected]%0A*/%0Afunction%20leoHighlightsSnooze%28%29%0A%7B%0A%20%20try%0A%20%20%7B%0A%20%20%20%20%20_leoHighlightsSnoozed%3Dtrue%3B%0A%20%20%20%20%20_leoHighlightsSimpleGwCallBack%28%22LeoHighlightsSnooze%22%29%3B%0A%20%20%7D%0A%20%20catch%28e%29%0A%20%20%7B%0A%20%20%20%20%20_leoHighlightsReportExeception%28%22leoHighlightsSnooze%28%29%22%2Ce%29%3B%20%20%20%20%0A%20%20%7D%0A%7D%0A%0A/**%0A*%0A*%20This%20is%20used%20to%20snooze%20the%20highlights.%0A*%20This%20gets%20fired%20into%20the%20top%20frame.%0A*%0A*%[email protected]%0A*/%0Afunction%20leoHighlightsSnoozeTop%28id%29%0A%7B%0A%20%20try%0A%20%20%7B%0A%20%20%20%20%20_leoHighlightsSnoozed%3Dtrue%3B%0A%20%20%20%20%20leoHighlightsHideElem%28id%29%3B%0A%20%20%7D%0A%20%20catch%28e%29%0A%20%20%7B%0A%20%20%20%20%20_leoHighlightsReportExeception%28%22leoHighlightsSnoozeTop%28%29%22%2Ce%29%3B%20%20%20%20%0A%20%20%7D%0A%7D%0A%0A%0A/**%0A%20*%20This%20should%20handle%20the%20click%20events%0A%20*%20%0A%20*%[email protected]%20anchorId%0A%20*%[email protected]%0A%20*/%0Afunction%20leoHighlightsHandleClick%28anchorId%29%0A%7B%0A%20%20%20try%0A%20%20%20%7B%0A%20%20%20%20%20%20if%28_leoHighlightsSnoozed%29%0A%20%20%20%20%20%20%20%20%20return%20false%3B%0A%20%20%20%20%20%20%0A%20%20%20%20%20%20if%28_leoHighlightsIsFrame%28%29%29%0A%20%20%20%20%20%20%20%20%20return%20false%3B%0A%20%20%20%20%20%20%0A%20%20%09%09var%20anchor%3D_leoHighlightsFindElementById%28anchorId%29%3B%0A%20%20%09%09anchor.hover%3Dfalse%3B%0A%20%20%09%09if%28anchor.startTimer%29%0A%20%20%09%09%09clearTimeout%28anchor.startTimer%29%3B%0A%20%20%20%09%0A%20%20%20%20%20%20/*%20Report%20the%20click%20event%20*/%0A%20%20%20%20%20%20leoHighlightsReportEvent%28%22clicked%22%2C%20window.document.domain%2C%0A%20%20%20%20%20%20%20%20%20%20%20%20_leoHighlightsGetAttrib%28anchor%2C%27leohighlights_keywords%27%29%2Cnull%2C%0A%20%20%20%20%20%20%20%20%20%20%20%20_leoHighlightsGetAttrib%28anchor%2C%27leohighlights_accept%27%29%2C%0A%20%20%20%20%20%20%20%20%20%20%20%20_leoHighlightsGetAttrib%28anchor%2C%27leohighlights_reject%27%29%29%3B%0A%20%20%20%20%20%20%0A%20%20%20%09leoHighlightsShowPopup%28anchorId%2C1%29%3B%0A%20%20%20%09return%20false%3B%0A%20%20%20%7D%0A%20%20%20catch%28e%29%0A%20%20%20%7B%0A%20%20%20%09_leoHighlightsReportExeception%28%22leoHighlightsHandleClick%28%29%22%2Ce%29%3B%20%20%20%09%0A%20%20%20%7D%09%0A%7D%0A%0A/**%0A%20*%20This%20should%20handle%20the%20hover%20events%0A%20*%20%0A%20*%[email protected]%20anchorId%0A%20*%[email protected]%0A%20*/%0Afunction%20leoHighlightsHandleHover%28anchorId%29%0A%7B%0A%20%20%20try%0A%20%20%20%7B%0A%20%20%20%20%20%20if%28_leoHighlightsSnoozed%29%0A%20%20%20%20%20%20%20%20%20return%20false%3B%0A%20%20%20%20%20%20%0A%20%20%20%20%20%20if%28_leoHighlightsIsFrame%28%29%29%0A%20%20%20%20%20%20%20%20%20return%20false%3B%0A%20%20%20%20%20%20%0A%20%20%09%09var%20anchor%3D_leoHighlightsFindElementById%28anchorId%29%3B%0A%20%20%09%09anchor.hover%3Dtrue%3B%0A%20%20%09%09%0A%20%20%20%20%20%20/*%20Report%20the%20hover%20event%20*/%0A%20%20%20%20%20%20leoHighlightsReportEvent%28%22hovered%22%2C%20window.document.domain%2C%0A%20%20%20%20%20%20%20%20%20%20%20%20_leoHighlightsGetAttrib%28anchor%2C%27leohighlights_keywords%27%29%2Cnull%2C%0A%20%20%20%20%20%20%20%20%20%20%20%20_leoHighlightsGetAttrib%28anchor%2C%27leohighlights_accept%27%29%2C%0A%20%20%20%20%20%20%20%20%20%20%20%20_leoHighlightsGetAttrib%28anchor%2C%27leohighlights_reject%27%29%29%3B%0A%20%20%20%20%20%20%0A%20%20%20%09leoHighlightsShowPopup%28anchorId%2C0%29%3B%0A%20%20%20%09return%20false%3B%0A%20%20%20%7D%0A%20%20%20catch%28e%29%0A%20%20%20%7B%0A%20%20%20%09_leoHighlightsReportExeception%28%22leoHighlightsHandleHover%28%29%22%2Ce%29%3B%20%20%20%09%0A%20%20%20%7D%09%0A%7D%0A%0A/**%0A%20*%20This%20will%20handle%20the%20mouse%20over%20setup%20timers%20for%20the%20appropriate%20timers%0A%20*%20%0A%20*%[email protected]%20id%0A%20*%[email protected]%0A%20*/%0Afunction%20leoHighlightsHandleMouseOver%28id%29%0A%7B%0A%09try%0A%09%7B%0A%20%20%20%20%20%20if%28_leoHighlightsSnoozed%29%0A%20%20%20%20%20%20%20%20%20return%3B%0A%09%20%20%20%0A%09%20%20%20if%28_leoHighlightsIsFrame%28%29%29%0A%09%20%20%20%20%20%20return%3B%0A%09%20%20%20%0A%09%09var%20anchor%3D_leoHighlightsFindElementById%28id%29%3B%09%09%0A%0A%09%09/*%20Clear%20the%20end%20timer%20if%20required%20*/%0A%09%09if%28anchor.endTimer%29%0A%09%09%09clearTimeout%28anchor.endTimer%29%3B%0A%09%09anchor.endTimer%3Dnull%3B%0A%09%09%0A%09%09anchor.style.background%3DLEO_HIGHLIGHTS_BACKGROUND_STYLE_HOVER%3B%0A%09%09%0A%09%09var%20underline%3D_leoHighlightsGetAttrib%28anchor%2C%22leohighlights_underline%22%29%3D%3D%27true%27%3B%0A%09%09%0A%09%09/*%20The%20element%20is%20already%20showing%20we%20are%20done%20*/%0A%09%09if%28anchor.shown%29%0A%09%09%09return%3B%0A%09%09%0A%09%09/*%20Setup%20the%20start%20timer%20if%20required%20*/%0A%09%09anchor.startTimer%3DsetTimeout%28function%28%29%7B%0A%09%09%09leoHighlightsHandleHover%28anchor.id%29%3B%0A%09%09%09anchor.hover%3Dtrue%3B%0A%09%09%09%7D%2Cunderline?LEO_HIGHLIGHTS_SHOW_DELAY_MS%3ALEO_HIGHLIGHTS_SHOW_DELAY_NO_UNDER_MS%29%3B%0A%09%7D%0A%09catch%28e%29%0A%09%7B%0A%09%09_leoHighlightsReportExeception%28%22leoHighlightsHandleMouseOver%28%29%22%2Ce%29%3B%20%20%20%09%0A%09%7D%0A%7D%0A%0A/**%0A%20*%20This%20will%20handle%20the%20mouse%20over%20setup%20timers%20for%20the%20appropriate%20timers%0A%20*%20%0A%20*%[email protected]%20id%0A%20*%[email protected]%0A%20*/%0Afunction%20leoHighlightsHandleMouseOut%28id%29%0A%7B%0A%09try%0A%09%7B%09%0A%09%09var%20anchor%3D_leoHighlightsFindElementById%28id%29%3B%0A%09%09%0A%09%09/*%20Clear%20the%20start%20timer%20if%20required%20*/%0A%09%09if%28anchor.startTimer%29%0A%09%09%09clearTimeout%28anchor.startTimer%29%3B%0A%09%09anchor.startTimer%3Dnull%3B%0A%09%09%0A%09%09anchor.style.background%3DLEO_HIGHLIGHTS_BACKGROUND_STYLE_DEFAULT%3B%0A%09%09if%28%21anchor.shown||%21anchor.hover%29%0A%09%09%09return%3B%0A%09%09%0A%09%09/*%20Setup%20the%20start%20timer%20if%20required%20*/%0A%09%09anchor.endTimer%3DsetTimeout%28function%28%29%7B%0A%09%09%09leoHighlightsHideElem%28LEO_HIGHLIGHTS_IFRAME_DIV_ID%29%3B%0A%09%09%09anchor.shown%3Dfalse%3B%0A%09%09%09_leoHighlightsPrevElem%3Dnull%3B%0A%09%09%09%7D%2CLEO_HIGHLIGHTS_HIDE_DELAY_MS%29%3B%0A%09%7D%0A%09catch%28e%29%0A%09%7B%0A%09%09_leoHighlightsReportExeception%28%22leoHighlightsHandleMouseOut%28%29%22%2Ce%29%3B%20%20%20%09%0A%09%7D%0A%7D%0A%0A/**%0A%20*%20This%20handles%20the%20mouse%20movement%20into%20the%20currently%20opened%20window.%0A%20*%20Just%20clear%20the%20close%20timer%0A%20*%20%0A%20*%[email protected]%0A%20*/%0Afunction%20leoHighlightsHandleIFrameMouseOver%28%29%0A%7B%0A%09try%0A%09%7B%0A%09%09if%28_leoHighlightsPrevElem%26%26_leoHighlightsPrevElem.endTimer%29%0A%09%09%09clearTimeout%28_leoHighlightsPrevElem.endTimer%29%3B%0A%09%7D%0A%09catch%28e%29%0A%09%7B%0A%09%09_leoHighlightsReportExeception%28%22leoHighlightsHandleIFrameMouseOver%28%29%22%2Ce%29%3B%20%20%20%09%0A%09%7D%0A%7D%0A%0A/**%0A%20*%20This%20handles%20the%20mouse%20movement%20into%20the%20currently%20opened%20window.%0A%20*%20Just%20clear%20the%20close%20timer%0A%20*%20%0A%20*%[email protected]%20id%0A%20*%[email protected]%0A%20*/%0Afunction%20leoHighlightsHandleIFrameMouseOut%28%29%0A%7B%0A%09try%0A%09%7B%0A%09%09if%28_leoHighlightsPrevElem%29%0A%09%09%09leoHighlightsHandleMouseOut%28_leoHighlightsPrevElem.id%29%3B%0A%09%7D%0A%09catch%28e%29%0A%09%7B%0A%09%09_leoHighlightsReportExeception%28%22leoHighlightsHandleIFrameMouseOut%28%29%22%2Ce%29%3B%20%20%20%09%0A%09%7D%0A%7D%0A/**%0A%20*%20This%20is%20a%20method%20is%20used%20to%20make%20the%20javascript%20within%20IE%20runnable%0A%20*/%0Avar%20leoHighlightsRanUpdateDivs%3Dfalse%3B%0Afunction%20leoHighlightsUpdateDivs%28%29%0A%7B%0A%09try%0A%09%7B%0A%09%09/*%20Check%20if%20this%20is%20an%20IE%20browser%20and%20if%20divs%20have%20been%20updated%20already%20*/%0A%09%09if%28document.all%26%26%21leoHighlightsRanUpdateDivs%26%26%21_leoHighlightsIsFrame%28%29%29%0A%09%09%7B%0A%09%09%09leoHighlightsRanUpdateDivs%3Dtrue%3B%20//%20Set%20early%20to%20prevent%20running%20twice%0A%09%09%09for%28var%20i%3D0%3Bi%3CLEO_HIGHLIGHTS_MAX_HIGHLIGHTS%3Bi%2B%2B%29%0A%09%09%09%7B%0A%09%09%09%09var%20id%3D%22leoHighlights_Underline_%22%2Bi%3B%0A%09%09%09%09var%20elem%3D_leoHighlightsFindElementById%28id%29%3B%0A%09%09%09%09if%28elem%3D%3Dnull%29%0A%09%09%09%09%09break%3B%0A%09%09%09%09%0A%09%09%09%09if%28%21elem.leoChanged%29%0A%09%09%09%09%7B%0A%09%09%09%09%09elem.leoChanged%3Dtrue%3B%0A%09%09%09%09%0A%09%09%09%09%09/*%20This%20will%20make%20javaScript%20runnable%20*/%09%09%09%09%0A%09%09%09%09%09elem.outerHTML%3Delem.outerHTML%3B%0A%09%09%09%09%7D%0A%09%09%09%7D%0A%09%09%7D%0A%09%7D%0A%09catch%28e%29%0A%09%7B%0A%09%09_leoHighlightsReportExeception%28%22leoHighlightsUpdateDivs%28%29%22%2Ce%29%3B%20%20%20%09%0A%09%7D%0A%7D%0A%0Aif%28document.all%29%0A%09setTimeout%28leoHighlightsUpdateDivs%2C200%29%3B%0A%0A%0A/**%0A%20*%20This%20is%20used%20to%20report%20events%20to%20the%20plugin%0A%20*%[email protected]%20key%0A%20*%[email protected]%20domain%0A%20*%[email protected]%20keywords%0A%20*%[email protected]%20vendorId%0A%20*%[email protected]%20accept%0A%20*%[email protected]%20reject%0A%20*%[email protected]%0A%20*/%0Afunction%20leoHighlightsReportEvent%28key%2C%20domain%2Ckeywords%2CvendorId%2Caccept%2Creject%29%0A%7B%0A%20%20%20try%0A%20%20%20%7B%0A%20%20%20%20%20%20var%20gwObj%20%3D%20new%20Gateway%28%29%3B%0A%20%20%20%20%20%20gwObj.addParam%28%22key%22%2Ckey%29%3B%0A%20%20%20%20%20%20if%28domain%21%3Dnull%29%0A%20%20%20%20%20%20%20%20%20gwObj.addParam%28%22domain%22%2Cdomain%29%3B%0A%20%20%20%20%20%20if%28keywords%21%3Dnull%29%0A%20%20%20%20%20%20%20%20%20gwObj.addParam%28%22keywords%22%2Ckeywords%29%3B%0A%20%20%20%20%20%20if%28vendorId%21%3Dnull%29%0A%20%20%20%20%20%20%20%20%20gwObj.addParam%28%22vendorId%22%2CvendorId%29%3B%0A%20%20%20%20%20%20if%28accept%21%3Dnull%29%0A%20%20%20%20%20%20%20%20%20gwObj.addParam%28%22accept%22%2Caccept%29%3B%0A%20%20%20%20%20%20if%28reject%21%3Dnull%29%0A%20%20%20%20%20%20%20%20%20gwObj.addParam%28%22reject%22%2Creject%29%3B%0A%20%20%20%20%20%20%0A%20%20%20%20%20%20gwObj.callName%28%22LeoHighlightsEvent%22%29%3B%0A%20%20%20%7D%0A%20%20%20catch%28e%29%0A%20%20%20%7B%0A%20%20%20%20%20%20_leoHighlightsReportExeception%28%22leoHighlights%28%29%22%2Ce%29%3B%20%20%20%20%20%0A%20%20%20%7D%0A%7D%0A%0A/**%0A%20*%20This%20will%20expand%20or%20collapse%20the%20window%20base%20on%20it%20prior%20state%0A%20*%20%0A%20*%[email protected]%0A%20*/%0Afunction%20leoHighlightsToggleSize%28clickId%29%0A%7B%0A%20%20%20try%0A%20%20%20%7B%20%20%0A%20%20%20%20%20%20_leoHighlightsDebugLog%28%22leoHighlightsToggleSize%28%29%20%22%2B_leoHighlightsPrevElem%29%3B%20%20%20%20%20%20%20%20%20%20%20%20%0A%20%20%20%20%20%20/*%20Get%20the%20hover%20flag%20and%20change%20the%20status%20*/%0A%20%20%20%20%20%20var%20size%3D_leoHighlightsPrevElem.hover?1%3A0%3B%0A%20%20%20%20%20%20_leoHighlightsSetBottomSize%28size%2CclickId%29%3B%0A%20%20%20%7D%0A%20%20%20catch%28e%29%0A%20%20%20%7B%0A%20%20%20%20%20%20_leoHighlightsReportExeception%28%22leoHighlightsToggleSize%28%29%22%2Ce%29%3B%20%20%20%20%20%0A%20%20%20%7D%0A%7D%0A%0A/**%0A%20*%20Call%20into%20the%20kvm%20that%20will%20then%20do%20a%20callback%20into%20the%20top%20window%0A%20*%20The%20top%20window%20will%20then%20call%20leoH%0A%20*%20%0A%20*%[email protected]%0A%20*/%0Afunction%20leoHighlightsSetSecondaryWindowUrl%28url%2C%20customerId%2C%20phraseId%29%0A%7B%0A%20%20%20try%0A%20%20%20%7B%20%0A%20%20%20%20%20%20_leoHighlightsDebugLog%28%22leoHighlightsSetSecondaryWindowUrl%28%29%20%22%2Burl%29%3B%20%20%20%20%20%20%20%20%20%20%20%20%0A%20%20%20%20%20%20var%20gwObj%20%3D%20new%20Gateway%28%29%3B%0A%20%20%20%20%20%20gwObj.addParam%28%22url%22%2C%20url%29%3B%0A%20%20%20%20%20%20gwObj.addParam%28%22phraseId%22%2C%20phraseId%29%3B%0A%20%20%20%20%20%20gwObj.addParam%28%22customerId%22%2C%20customerId%29%3B%0A%20%20%20%20%20%20gwObj.callName%28%22LeoHighlightsSetSecondaryWindowUrl%22%29%3B%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0A%20%20%20%7D%0A%20%20%20catch%28e%29%0A%20%20%20%7B%0A%20%20%20%20%20%20_leoHighlightsReportExeception%28%22leoHighlightsSetSecondaryWindowUrl%28%29%22%2Ce%29%3B%20%20%20%20%20%0A%20%20%20%7D%0A%7D%0A%0A/**%0A%20*%20Call%20into%20the%20kvm%20that%20will%20then%20do%20a%20callback%20into%20the%20top%20window%0A%20*%20The%20top%20window%20will%20then%20call%20leoH%0A%20*%20%0A%20*%[email protected]%0A%20*/%0Afunction%20leoHighlightsSetSecondaryWindowUrlCallback%28url%2C%20customerId%2C%20phraseId%29%0A%7B%0A%20%20%20try%0A%20%20%20%7B%20%0A%20%20%20%20%20%20_leoHighlightsDebugLog%28%22leoHighlightsSetSecondaryWindowUrlCallback%28%29%20%22%2Burl%29%3B%0A%20%20%20%20%20%20%0A%20%20%20%20%20%20/*%20Clear%20the%20hover%20flag%2C%20if%20the%20user%20shows%20this%20at%20full%20size%20*/%0A%20%20%20%20%20%20var%20size%3D_leoHighlightsPrevElem.hover?0%3A1%3B%20%20%20%20%20%20%0A%20%20%20%20%20%20_leoHighlightsDebugLog%28%22leoHighlightsSetSecondaryWindowUrlCallback%28%29%20%22%2B_leoHighlightsPrevElem%2B%22%20--%20%22%2B_leoHighlightsPrevElem.hover%29%3B%0A%20%20%20%20%20%20%0A%20%20%20%20%20%20/*%20Get%20the%20elements%20*/%0A%20%20%20%20%20%20var%20iFrameBottom%3D_leoHighlightsFindElementById%28LEO_HIGHLIGHTS_IFRAME_BOTTOM_ID%29%3B%0A%20%20%20%20%20%20leoHighlightsUpdateUrl%28iFrameBottom%2Csize%2Cnull%2Curl%29%3B%0A%20%20%20%20%20%20%0A%20%20%20%20%20%20_leoHighlightsDebugLog%28%22leoHighlightsSetSecondaryWindowUrlCallback%28%29%20%22%2Burl%29%3B%20%20%20%20%20%20%20%20%20%20%20%20%0A%20%20%20%7D%0A%20%20%20catch%28e%29%0A%20%20%20%7B%0A%20%20%20%20%20%20_leoHighlightsReportExeception%28%22leoHighlightsSetSecondaryWindowUrlCallback%28%29%22%2Ce%29%3B%20%20%20%20%20%0A%20%20%20%7D%0A%7D%0A%0A/**%0A%20*%20This%20will%20set%20the%20text%20to%20the%20Top%20%0A%20*%20%0A%20*%[email protected]%20txt%0A%20*%[email protected]%0A%20*/%0Afunction%20leoHighlightsSetExpandTxt%28txt%29%0A%7B%0A%20%20%20try%0A%20%20%20%7B%20%0A%20%20%20%20%20%20var%20topIFrame%20%3D%20_leoHighlightsFindElementById%28LEO_HIGHLIGHTS_IFRAME_TOP_ID%29%3B%0A%20%20%20%20%20%20if%28topIFrame%3D%3Dnull%29%0A%20%20%20%20%20%20%20%20%20return%3B%0A%20%20%20%20%20%20%0A%20%20%20%20%20%20/*%20Get%20the%20current%20url%20*/%0A%20%20%20%20%20%20var%20url%3DtopIFrame.src%3B%20%20%20%20%20%20%0A%20%20%20%20%20%20if%28url%3D%3Dnull%29%0A%20%20%20%20%20%20%20%20%20return%3B%0A%20%20%20%20%20%20%0A%20%20%20%20%20%20/*%20Extract%20the%20previous%20hash%20if%20present%20*/%0A%20%20%20%20%20%20var%20idx%3D-1%3B%20%20%20%20%20%20%0A%20%20%20%20%20%20if%28%28idx%3Durl.indexOf%28%27%23%27%29%29%3E0%29%0A%20%20%20%20%20%20%20%20%20url%3Durl.substring%280%2Cidx%29%3B%0A%0A%20%20%20%20%20%20/*%20Append%20the%20text%20to%20the%20end%20*/%0A%20%20%20%20%20%20url%2B%3D%22%23%22%2BencodeURI%28txt%29%3B%0A%20%20%20%20%20%20%0A%20%20%20%20%20%20/*%20Set%20the%20iframe%20with%20the%20new%20url%20that%20contains%20the%20hash%20tag%20*/%0A%20%20%20%20%20%20topIFrame.src%3Durl%3B%0A%20%20%20%7D%0A%20%20%20catch%28e%29%0A%20%20%20%7B%0A%20%20%20%20%20%20_leoHighlightsReportExeception%28%22leoHighlightsSetExpandTxt%28%29%22%2Ce%29%3B%20%20%20%20%20%0A%20%20%20%7D%0A%7D%0A%0A/*----------------------------------------------------------------------*/%0A/*%20Methods%20provided%20to%20the%20highlight%20providers...%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20*/%0A/*----------------------------------------------------------------------*/%0A%0A/**%0A%20*%20This%20will%20set%20the%20expand%20text%20for%20the%20Top%20window%0A%20*/%0Afunction%20leoHL_SetExpandTxt%28txt%29%0A%7B%0A%20%20%20try%0A%20%20%20%7B%0A%20%20%20%20%20%20_leoHighlightsDebugLog%28%22leoHL_SetExpandTxt%28%29%20%22%2Btxt%29%3B%20%20%20%20%20%20%20%20%20%20%20%20%0A%20%20%20%20%20%20_leoHighlightsSimpleGwCallBack%28%22LeoHighlightsSetExpandTxt%22%2C%22expandTxt%22%2Ctxt%29%3B%20%20%20%20%20%20%0A%20%20%20%7D%0A%20%20%20catch%28e%29%0A%20%20%20%7B%0A%20%20%20%20%20%20_leoHighlightsReportExeception%28%22leoHL_SetExpandTxt%28%29%22%2Ce%29%3B%20%20%20%20%0A%20%20%20%7D%0A%7D%0A%0A/**%0A%20*%20This%20will%20redirect%20the%20top%20window%20to%20the%20passed%20in%20url%0A%20*%20%0A%20*%[email protected]%20url%0A%20*%[email protected]%20parentId%0A%20*%[email protected]%0A%20*/%0Afunction%20leoHL_RedirectTop%28url%2CparentId%29%0A%7B%0A%20%20%20try%0A%20%20%20%7B%20%0A%20%20%20%20%20%20try%7B%0A%20%20%20%20%20%20%20%20%20var%20domain%3D_leoHighlightsGetUrlArg%28window.document.URL%2C%22domain%22%29%0A%20%20%20%20%20%20%20%20%20var%20keywords%3D_leoHighlightsGetUrlArg%28window.document.URL%2C%22keywords%22%29%0A%20%20%20%20%20%20%20%20%20var%20vendorId%3D_leoHighlightsGetUrlArg%28window.document.URL%2C%22vendorId%22%29%0A%20%20%20%20%20%20leoHighlightsReportEvent%28%22clickthrough%22%2C%20domain%2Ckeywords%2C%20vendorId%29%3B%0A%20%20%20%20%20%20%7Dcatch%28e%29%7B%0A%20%20%20%20%20%20%20%20%20_leoHighlightsReportExeception%28%22leoHL_RedirectTop%28%29%22%2Ce%29%3B%20%20%20%20%0A%20%20%20%20%20%20%7D%0A%20%20%09%09%0A%20%20%20%09_leoHighlightsRedirectTop%28url%29%3B%0A%20%20%20%7D%0A%20%20%20catch%28e%29%0A%20%20%20%7B%0A%20%20%20%09_leoHighlightsReportExeception%28%22leoHL_RedirectTop%28%29%22%2Ce%29%3B%20%20%20%09%0A%20%20%20%7D%0A%7D%0A%0A/**%0A%20*%20This%20will%20redirect%20the%20top%20window%20to%20the%20passed%20in%20url%0A%20*%20%0A%20*%[email protected]%20url%0A%20*%[email protected]%20parentId%0A%20*%[email protected]%0A%20*/%0Afunction%20LeoHL_RedirectTop%28url%2CparentId%29%0A%7B%0A%20%20%20leoHL_RedirectTop%28url%2CparentId%29%3B%0A%7D%0A%0A/**%0A%20*%20This%20will%20redirect%20the%20top%20window%20to%20the%20passed%20in%20url%0A%20*%20%0A%20*%[email protected]%20url%0A%20*%[email protected]%20parentId%0A%20*%[email protected]%0A%20*/%0Afunction%20leoHL_RedirectTopAd%28url%2CparentId%29%0A%7B%0A%20%20%20try%0A%20%20%20%7B%20%0A%20%20%20%20%20%20try%7B%0A%20%20%20%20%20%20%20%20%20var%20domain%3D_leoHighlightsGetUrlArg%28window.document.URL%2C%22domain%22%29%0A%20%20%20%20%20%20%20%20%20var%20keywords%3D_leoHighlightsGetUrlArg%28window.document.URL%2C%22keywords%22%29%0A%20%20%20%20%20%20%20%20%20var%20vendorId%3D_leoHighlightsGetUrlArg%28window.document.URL%2C%22vendorId%22%29%0A%20%20%20%20%20%20leoHighlightsReportEvent%28%22advertisement.click%22%2C%20domain%2Ckeywords%2C%20vendorId%29%3B%0A%20%20%20%20%20%20%7Dcatch%28e%29%7B%0A%20%20%20%20%20%20%20%20%20_leoHighlightsReportExeception%28%22leoHL_RedirectTopAd%28%29%22%2Ce%29%3B%20%20%20%20%0A%20%20%20%20%20%20%7D%0A%20%20%20%20%20%20%0A%20%20%20%20%20%20_leoHighlightsRedirectTop%28url%29%3B%0A%20%20%20%7D%0A%20%20%20catch%28e%29%0A%20%20%20%7B%0A%20%20%20%20%20%20_leoHighlightsReportExeception%28%22leoHL_RedirectTopAd%28%29%22%2Ce%29%3B%20%20%20%20%0A%20%20%20%7D%0A%7D%0A%0A%0A/**%0A%20*%20This%20will%20set%20the%20size%20of%20the%20iframe%0A%20*%20%0A%20*%[email protected]%20url%0A%20*%[email protected]%20parentId%0A%20*%20%0A%20*%[email protected]%0A%20*/%0Afunction%20leoHl_setSize%28size%2Curl%29%0A%7B%0A%20%20%20try%0A%20%20%20%7B%0A%20%20%20%09/*%20Get%20the%20clickId%20*/%0A%20%20%20%09var%20clickId%3D_leoHighlightsGetUrlArg%28%20url%2C%22clickId%22%29%0A%20%20%20%09%0A%20%20%20%20%20%20var%20gwObj%20%3D%20new%20Gateway%28%29%3B%0A%20%20%20%20%20%20gwObj.addParam%28%22size%22%2Csize%29%3B%0A%20%20%20%20%20%20if%28clickId%29%0A%20%20%20%20%20%20%20%20%20gwObj.addParam%28%22clickId%22%2CclickId%2B%22_blah%22%29%3B%0A%20%20%20%20%20%20gwObj.callName%28%22LeoHighlightsSetSize%22%29%3B%0A%20%20%20%7D%0A%20%20%20catch%28e%29%0A%20%20%20%7B%0A%20%20%20%09_leoHighlightsReportExeception%28%22leoHl_setSize%28%29%22%2Ce%29%3B%20%20%20%09%0A%20%20%20%7D%0A%7D%0A%0A/**%0A%20*%20This%20will%20toggle%20the%20size%20of%20the%20window%0A%20*%20%0A%20*%[email protected]%0A%20*/%0Afunction%20leoHl_ToggleSize%28%29%0A%7B%0A%20%20%20try%0A%20%20%20%7B%0A%20%20%20%20%20%20var%20gwObj%20%3D%20new%20Gateway%28%29%3B%0A%20%20%20%20%20%20gwObj.callName%28%22LeoHighlightsToggleSize%22%29%3B%0A%20%20%20%7D%0A%20%20%20catch%28e%29%0A%20%20%20%7B%0A%20%20%20%20%20%20_leoHighlightsReportExeception%28%22leoHl_ToggleSize%28%29%22%2Ce%29%3B%20%20%20%20%20%0A%20%20%20%7D%0A%7D%0A%0A"); </script>
You can always buy it later.
or wear the brakes out @ 49,000 miles :)
My bet is that since Pete has been silent; he has purchased the car and is preparing a Christmas pictorial for all of us to see and enjoy. It sounds like a very nice car. C'mon Pete, show us your new ride! :biggrinbounce: :cheers:
Discussion Starter · #19 · (Edited)
haha, good call. I'll do some 0-100-0 time trials at 49k to get the brakes down to the metal. Is EM transferable? What about the CPO warranty?
dnt - haven't purchased it yet (may even have been sold already). I'm still deciding whether buying is the CPO is worth it vs. non-CPO + extended warranty.
Slow and cautious is good.
If it sold, you can bet another deal will come up.
My father in law sold GM for ~45 yrs and he called it the iron business.
He's say iron sells every day and it's all negotiable.
I respect a cautious, well educated buyer (as I too am one).
1 - 20 of 30 Posts
