1 - 7 of 7 Posts
2007 BMW M6 6-speed Manual
2007 BMW M6 Coupe, 6-speed manual V10, 121,000 miles. No accidents, Meticulously maintained, no issues or imminent service, rod bearings and other recent service history listed below. Secondary cat/resonator delete with x-pipe. Evolve Stage 2 tune: 93 octane, 8500rpm redline, VMAX delete. Rock chips in the front bumper, otherwise cosmetically great for its age/miles driven. Painted (black) carbon fiber roof recently wrapped with protective carbon fiber vinyl. Comfort access (2x FOBs), soft close doors, HUD, Individual Sound, merino leather with carbon fiber trim. Leather dash has some "shrinkage" that has improved with leather balm treatments. The rear end makes some noise when cold but goes away after a few turns (noise started after switching to Redline + friction modifier, hasn't been annoying enough to switch back to the BMW fluid).
I have had the car in Germany for the last two years, it was shipped to and from in a container and is now back in Charlottesville, VA. I am asking $29,500 but will entertain well-informed offers. Post questions here or through PM.
120k - New front oil pan and transmission covers installed
119k - Replaced fuel filter and o-ring seal
118k- Installed stainless steel brake lines, brake and clutch fluid replaced
117k- Secondary cat and resonator bypass installed with x-pipe - primary cats and stock mufflers remain
117k- Oil and filter change
116k- Transmission and differential oil change (Redline oils) magnetic diff plug installed
115k- Replaced connecting rod bearings, Replaced VANOS high pressure line, Repaired stripped oil pan threads (work performed by MW Performance in Rockenhausen, Germany)
112k- Replaced 10x spark plugs, 4 ignition coils, cabin air filters, engine air filters, 2x beauty cover grommets, 2x airbox clips and Cleaned MAF sensors
111k - Replaced 4 tires and 1x ignition coil
110k- Alternator replaced, coolant replaced
Included in sale:
  • original chrome kidney grills and side grills
  • original exhaust section 2
  • car cover
  • Replacement rear brake rotors, pads and wear sensors
  • Extra Castrol TWS Supercar oil
  • New BMC air filters
  • Solar battery charging system
  • spare front wheel with TPMS sensor
  • miscellaneous small spare clips, seals, etc
  • Laptop with cable and NCS expert/TIS/etc preloaded
Vehicle Car Steering part Motor vehicle Steering wheel
Wheel Tire Vehicle Car Hood
Wheel Tire Car Vehicle Window
Automotive parking light Grille Vehicle Hood Automotive lighting
Car Wheel Vehicle Land vehicle Tire
Automotive parking light Car Vehicle Automotive tail & brake light Wheel
Automotive tail & brake light Vehicle registration plate Land vehicle Vehicle Car
Car Wheel Tire Vehicle Plant
Tire Wheel Car Vehicle Vehicle registration plate
Land vehicle Car Vehicle Automotive tire Hood
Discussion Starter · #2 · (Edited)
Updated price and car location. After sitting in the shipping container for over a month it fired right up. It is at BMW of Charlottesville getting some new underbody panels (oil pan/transmission) installed. I plan to keep driving it until the cold weather arrives so the mileage will keep going up. There's not a better sorted 6-speed S85 driver for sale anywhere right now.
Vehicle Motor vehicle Grille Automotive tire Automotive lighting
Vehicle Car Motor vehicle Automotive design Car seat cover
Car Vehicle Vehicle registration plate Grille Automotive lighting
Font Gadget Technology Electronic device Display device
Tire Wheel Vehicle Car Automotive tire
Wheel Tire Car Vehicle Automotive tire
Tire Wheel Vehicle Automotive tire Car
White Light Automotive tire Black Hood
Speedometer Motor vehicle Gauge Odometer Trip computer
Underbody panels were installed without issue. I used it for my 200mi commute 3 times this week and it ran like a dream, a dream with lots of gas stations in it.
Discussion Starter · #7 ·
soo about that radioactive material...
Funny you should mention that, I have shown that picture many times and no one has even mentioned that being in the background. Unfortunately I think all that radiation exposure took its toll on my throttle actuator gears :unsure:...Seriously though, I had the DSC/reduced power/etc fault codes at startup this morning. I will get it sorted out in the next few days, but it is looking like the next owner will have one less thing to worry about.
1 - 7 of 7 Posts
