1 - 2 of 2 Posts
brothers ,I recently rebuilt my transmission ( new flywheel clutch ,differential ,sensors )my problem is that when the indy shop i take my beast to hooks up to program the transmission it does not accept the coding. Does anyone have a clue as to what the issue may be? The beast despite the trans malfunction being active. It has no reduce power. It shifts fine up and down the gears But after about 15 minutes as I shift the transmission hesitates trying to deterkine what gear it should be in.HELP!!
Try to bleed the clutch slave 4-5 times, check SMG oil level before and after, delete faults and do adaptation procedure again.
1 - 2 of 2 Posts
