My driver side window motor toasted itself trying to move on a cold day. The car still started and drove, but fuse 10 had gone out. Servotronic malfunction error with heavy steering and no response from the window. Same issue as detailed a couple times before:
www.bimmerfest.com
www.bimmerforums.co.uk
I replaced fuse 10 the same day which brought back normal steering, but the window motor was still gone with an anti-trap warning present. I drove the car like normal thinking I would order a new motor and drive it in the mean time. A few days later, the steering lock stuck (yellow icon) and the car would not start. Thinking it was a battery issue, I took the battery out of the car and charged it up at home. The next morning, the car started fine. Thinking my problems were solved, I turned it off after a few minutes and went inside. By lunch time, it was back to the no start condition.
At this point I had it towed to the local BMW dealer to check the codes. They refused to check and codes and just told me it needs a steering column replaced for $3800 CAD. Tried the battery charge trick a second time to no avail. Also tried unplugging IBS but that did not work either. In the mean time I ordered a new steering lock module and a window motor that I will have an indy mechanic put in, but I just have a hard time believing that the steering lock died after 16 years of service exactly two days after an electrical fault elsewhere in the car. Anything else I can try to get this back on the road quicker?
Window motor blown??.
Hi, Having a bit of a nightmare after the snow snap here. Tried to open up the car when all frozen and was unable to so ended up locking it and running into work. I did notice however, that the window motor was trying to open up the frozen window and making a noise. Long story short, weather...
2007 E63 650i KGM Terminal 30A error
Hi everyone, I'm a new member having some trouble with my 650i hopefully someone with more experience than me can offer guidance, went out to the car yesterday to defrost it and even after a good 10/15mins warming up the drivers window would not move. I engaged reverse thinking it maybe needed...
