1 - 5 of 5 Posts
Dear Hasan, thanks for your reply but this subject have been raised and couldn't find it and anyways there is a subject releated to it "below"
http://www.m5board.com/vbulletin/e63-bmw-m6-forum-bmw-m6-convertible-m6board-com/80874-recall-m6-steering-angle-sensor.html
Interesting!
Still it says nothing on the Steering angle sensor. Besides that information is for NA cars.
You can check with Al Fardan if your car has any parts that need to be replaced.
Although this is a BMWNA notice I would believe some non-USA cars had similar issues. Non safety recalls are called "Service Action" in BMWNA speak
<TABLE cellPadding=4 width=720 bgColor=white><TBODY><TR><TD bgColor=white>
</TD><TD vAlign=top width=394>SI B34 05 06
Brakes
</TD><TD vAlign=top width=240>September 2006
Technical Service
</TD></TR></TBODY></TABLE>
This Service Information bulletin supersedes S.I. B34 05 06 dated August 2006.
PERFORM THE PROCEDURE OUTLINED IN THIS SERVICE INFORMATION ON ALL AFFECTED VEHICLES THE NEXT TIME THEY ARE IN THE SHOP FOR MAINTENANCE OR REPAIRS AND PRIOR TO RETAIL DELIVERY.
SUBJECT
Service Action: Replace SZL Optical Element
MODEL
E60, E61 (5 Series)
E63, E64 (6 Series)
SITUATION
The optical sensor in the SZL (Steering Column Switch Sensor) may fail.
A defective optical steering angle sensor leads to failure of Active Steering, DSC (Dynamic Stability Control), ARS (Active Roll Stabilization), AHL (Adaptive Headlights), ACC (Active Cruise Control) and the automatic turn signal reset function.
The failure of DSC, ARS and Active Steering is indicated by indicator lamps and display messages.
Note: One or more systems may fail, depending on the degree of damage to the optical steering angle sensor.
This Service Action checks the SZL and replaces the optical element if necessary.
A copy of the customer notification letter is attached.
To minimize the customer's inconvenience caused by this Service Action, pick-up (and deliver after repair) the affected vehicle from customer's home and provide appropriate alternative transportation.
Customers will be impressed when you return their cars cleaned inside and out and with a full tank of gas. Reimbursement information for the vehicle fueling and valet costs may be found in the Warranty portion of this bulletin.
AFFECTED VEHICLES
This Service Action involves E60, E61 (5 Series), E63, E64 (6 Series) vehicles, which were produced from August 26, 2005 to July 28, 2006.
In order to determine if a specific vehicle is affected by this Service Action, it will be necessary to utilize the "Service Menu" of the DCS (Dealer Communication System). Based on the response of the system, either proceed with the corrective action or take no further action.
The Chassis Number Ranges listed below are only for informational purposes and are not to be considered as the only deciding factor.
<TABLE cellSpacing=2 cellPadding=5 width=610 border=0><TBODY><TR><TD>Model
</TD><TD>Chassis Number Range
</TD></TR><TR><TD>525i
</TD><TD>B992184 – B992391
</TD></TR><TR><TD>525iA
</TD><TD>CK85662 – CK92999
</TD></TR><TR><TD></TD><TD>CW59001 – CW60610
</TD></TR><TR><TD>525xi
</TD><TD>B999084 – B999218
</TD></TR><TR><TD>525xiA
</TD><TD>CS35522 – CS39334
</TD></TR><TR><TD>530i
</TD><TD>B996273 – B996633
</TD></TR><TR><TD>530iA
</TD><TD>CM38342 – CM46872
</TD></TR><TR><TD>530xi
</TD><TD>CC34216 – CC34694
</TD></TR><TR><TD>530xiA
</TD><TD>CG67933 – CG69999
</TD></TR><TR><TD></TD><TD>CU19000 – CU22830
</TD></TR><TR><TD>530xiT
</TD><TD>B799088 – B799204
</TD></TR><TR><TD>530xiTA
</TD><TD>CN02129 – CN03974
</TD></TR><TR><TD>550i
</TD><TD>CN93019 – CN93585
</TD></TR><TR><TD>550iA
</TD><TD>CP00022 – CP05112
</TD></TR><TR><TD>M5
</TD><TD>B581063 – B584900
</TD></TR><TR><TD>645CiA
</TD><TD>CF95411 – CF95414
</TD></TR><TR><TD>650Ci
</TD><TD>CR46004 – CR46236
</TD></TR><TR><TD>650CiA
</TD><TD>CR49007 – CR50900
</TD></TR><TR><TD>M6 Coupe
</TD><TD>B797012 – B797380
</TD></TR><TR><TD>645Cic
</TD><TD>B261310
</TD></TR><TR><TD>645CicA
</TD><TD>B328934 – B328946
</TD></TR><TR><TD>650Cic
</TD><TD>CN72005 – CN72289
</TD></TR><TR><TD>650CicA
</TD><TD>CN75006 – CN78834
</TD></TR><TR><TD>M6 Conv.
</TD><TD>CS32013 – CS32015
</TD></TR></TBODY></TABLE>PROCEDURE
  1. Turn the steering wheel so that the front wheels are in the straight-ahead position
  2. Follow the Repair Instructions RA 61 31 006 "Removing and installing/replacing fixture for steering column stalk (from 09/2005)" to the point where the SZL part number label is visible.
  3. Check the SZL control module as follows:
</TD><TD>
  • The SZL is OK if an "OK" label is affixed to the underside of the SZL near the part number label. No further actions are necessary.
</TD></TR><TR><TD>
</TD><TD>
  • If no "OK" label is present, check the part number (1) and the modification index number (2) against the table below. No further actions are necessary if the modification index number matches the part number shown.
</TD></TR></TBODY></TABLE><TABLE cellSpacing=2 cellPadding=5 width=610 border=0><TBODY><TR><TD>Part Number
</TD><TD>Modification index
</TD></TR><TR><TD>9 111 997
</TD><TD>02 (or higher)
</TD></TR><TR><TD>9 111 998
</TD></TR><TR><TD>9 111 999
</TD></TR><TR><TD>9 115 165
</TD><TD>03 (or higher)
</TD></TR><TR><TD>9 115 166
</TD></TR><TR><TD>9 115 167
</TD></TR><TR><TD>9 115 183
</TD></TR><TR><TD>9 115 184
</TD></TR><TR><TD>9 115 185
</TD></TR></TBODY></TABLE>4. Remove the SZL control unit.
</TD><TD>5. Remove the slip ring (rotary coupler). See Repair Instructions "Removal and fitting of the volute spring cassette", see RA 61 31 011.
6. The following should be observed in particular:
  • Do not turn ring (1). (Even turning ring (1) through 360deg; is not allowed.)
Put the slip ring aside for re-assembly later.
</TD></TR></TBODY></TABLE>7. Locate a clean workplace for the repair. An anti-static mat MUST be used – see SI B04 19 04. Put on the disposable gloves supplied in the parts set (only these gloves may be worn). THE UTMOST CLEANLINESS MUST BE ENSURED.
</TD><TD>8. Unscrew the four T9 Torx screws of the SZL housing. Lift open the cover by gently prying it out at position (1) (using a screwdriver).
</TD></TR><TR><TD>
</TD><TD>9. Unscrew the two T6 Torx screws to remove the optical element (1) from the board.
Important:
  • Touch nothing other than the optical element.
  • Under no circumstances should the SZL or optic disk be cleaned or wiped in any way. A visible haze on the optic disk has no negative effect on the operation of the SZL.
</TD></TR></TBODY></TABLE>10. Install the new optical element. Incorrect positioning is impossible because the optical element is mechanically coded. Carefully tighten the two Torx screws and do not over-tighten. (Tightening torque of approximately 0.35 Nm).
11. Reinstall the cover to the SZL control unit and tighten the four Torx screws. (Tightening torque of approximately 0.5 Nm). Take care not to trap the cable guide for the windshield wiper switch.
</TD><TD>12. Affix the "OK" label near the part number label position (2).
</TD></TR><TR><TD>
</TD><TD>13. Reinstall the rotary coupler (slip ring)
Note for correct installation:
Ring (1) must be positioned in the retainer (2) in such a way that opening (3) for the driving pin (of the rotary coupler) is at arrow position (4).
</TD></TR></TBODY></TABLE>14. Reinstall the SZL control unit.
Important: The SZL must not be reinstalled until all four cover screws have been tightened correctly.
15. Vehicles without Active Steering: perform steering angle sensor calibration (RA 61 31 996).
Vehicles with Active Steering: align the Active Steering (RA 32 10 005).
Note: No programming or coding is required
16. Carry out a short test drive to confirm a successful repair.
PARTS INFORMATION
</TD><TD>Description
</TD><TD>Quantity
</TD></TR><TR><TD>61 31 9 141 875
</TD><TD>SZL repair kit
</TD><TD>1
</TD></TR></TBODY></TABLE>LABEL INSTRUCTIONS
</TD><TD>This Service Action has been assigned code number 477. After the vehicle has been checked and corrected if necessary, obtain a label (SD 92-295) and:
  1. emboss your BMW dealer warranty number in the middle of the label (1),
  2. punch out code number 477 (2) printed on the label and,
  3. affix the label to the B pillar as shown.
</TD></TR></TBODY></TABLE>If the vehicle already has a label from a previous Service Action/Recall Campaign, affix the new label next to the old one. Do not affix one label on top of another one because a number from an underlying label could appear in the punched-out hole of the new label.
WARRANTY INFORMATION
Reimbursement for this Service Action will be via normal claim entry utilizing the following information:
1 - 5 of 5 Posts
