1 - 20 of 54 Posts
http://newyork.craigslist.org/wch/cto/4479878569.html
Fatory Options/features
Production date 02/2003
-120,000 miles but you would never guess it and if you may not want a car with mileage that high come look at it and see if you have the same opinion
- S62 4.9 Liter DOHC, double VANOS 32 valve V8 engine
-405 Imola Red exterior
-Black nappa leather sport seats (ostrich) extended leather
-titanium silver sport trim
-Split fold down rear seats
-Alcantara suede headliner
-DSP sound system
-Homelink garage door opener
-mk4 dvd navigation
--6-cd/disk changer
-Power and heated front seats with three-position memory for the driver.
-Power tilt and telescoping steering column.
-Automatic climate control.
-Cruise control.
-Extended on-board computer
-6-speed transmission.
-Sport mode
-LSD differential
-M tire pressure monitoring system
-M Mobility system
-Vehicle and key memory
-Anti theft alarm
-3 spoke Multifunction M sport steering wheel
-Rain sensing wipers
-Power 2-way moon-roof
-Phone preparation (button on armrest)
-premium hifi system
Suspension
-BC coil-overs spring rates 8k front 6k rear.(updated Koyo bearings, and extended adjusters.
-Rear lower ball joints, New snap rings 11/14/2012
-Integral links 11/14/2012
-Rear sway bar links 11/14/2012
-Front sway bar links 11/14/2012
-Front sway bar bushings 11/14/2012
-Rear control arms upper guide rods 12/14/2012
-Rear control arms lower 12/05/2012
-All 3 differential bushings 11/29/2012
-All 4 rear sub-frame bushings 11/29/2012
Engine/Transmission/Maintenance
-Brand new brake rotors to be installed this week
-Oil change this week as well
-Brake pads have a lot of life left and perform amazing
-New Starter 03/06/2013
-Emergency Brake cables 12/03/2012
-LUK Clutch kit, pilot bearing, throw out bearing, 11/06/2012
-sachs release bearing 11/07/2012
-Rear main seal 11/06/2012
-Rear differential pinion seal 11/02/2012
-Bosch windshield wipers 11/03/2012
-Oil separator hoses 11/03/2012
-Remove intake plenum and Clean/de-carbon throttle bodies
-New transmission shift detents springs and bearings 01/17/2013
-Oil changed with 10w60 full synthetic every 5k miles
-Transmission fluid change OEM fluids 1/17/2013
-Differential fluid exchange 01/17/2013
-Power steering flush ATF
-Brake flush DOT 4
-Coolant flush OEM fluid
-New Guibo/ drive shaft flex disk 01/17/2013
-New center support bearing 01/17/2013
-New drive shaft bushing 1/17/2013
-New front hood cables left and right 06/24/2013
-New air filters
-New cabin filters
-New transmission mounts
-Crankshaft seal 11/07/2012
-Crank position sensor 01/19/2013
-4 wheel laser alignment
Mods
-Staggered (Powdercoated) Gloss Black Authentic BBS RGRs
Front Offset: 20mm
Backspacing: 5.82"
Bolt Pattern: 5-120
Weight: 20lbs.
15mm spacer HR spacer, extended lug studs
Rear Offset: 25mm
Backspacing: 6.49"
Bolt Pattern: 5-120
Weight: 22.0lbs.
-275/35/19 Michelin PSS tires rears
-235/35/19 Michelin PS2 tires front
-Jailbreak Software tune/reflash- Rev limit raised to 7200rpms, Alpha N- tune (mafs not needed), speed delimiter, Sport memory function, rear cats turned off. ( Car made 333whp 332 torque on a Dyno Jet dyno before the reflash.
-15mm HR spacers front
-Extended lug studs
-Carbotech brake pads
-front fenders professionally rolled (Eastwood roller)
-Stainless steal twin Muffler tips staggered
-Muffler delete
-Window tint 15 percent
-Windshield tint 30 percent
-Black BMW emblems
-Black matt kidney grills
-LED full interior/trunk lighting kit (no error)
-LED License plate bulbs (no error)
-LED sidemarker bulbs (no error)
-(Diny)M5boards stainless steel Navigation knobs
-E60 SSK short shift kit with new bushings and cup washer. 11/06/2012
-Slimmbones big mouth front grill black 4inch
-Slimmbones Rear diffuser (black)
-Depo euro hella style headlights custom FXR 3.0 retrofitted projectors with 55w Morimoto ballasts
-LED angel eyes
-Black vinyl roof (Comes right off if you dont like the black roof)
-Clutch stop
-UUC rk5 stainless steel weighted shift knob 6-spd
I am selling my car because I need awd. I've owned it since August of 2013 and loved every minute of it. I've driven it 10,000 miles since I bought it and it has never given me any major problems at all.
This car is one of the strongest running M5s I've ever driven. Its mint condition except for a lil bit of body work needed, needs a new bumper(I already have an oem bumper just gotta paint it but I will include it in the sale),I got hit by a cab on my drivers side fender chipping a 2cm size of paint and a lil bit of paint chipping on the bottom right of the rear bumper from when I hit some rock hard snow backing up. I am more focused on maintaining the car mechanically rather than cosmetically which is why the exterior does have small problems but other than that the exterior is mint just one door ding on passenger door but its not noticeable.
Full disclosure
-Cracked front bumper(shown in pics in my craigslist ad)
-OEM bumper to be included with sale, just needs to be painted
-2cm paint chip on fender
-Paint chipping on bottom right of the rear bumper
-Minor paint imperfections but other than the above, it is in 9.5 condition outside and 8.5 inside
-Very small paint chip where the M5 badge goes on the trunk, it is currently debadged however I will include the badges with the sale.
-Like I said, only issues are cosmetic, I care more about mechanical condition than exterior condition although I was planning on fixing all the exterior issues if I wasn't selling the car
-No mechanical issues
-3 wheels have been powdercoated and the other one has been painted because it is welded and the shop who did it said they wouldn't powdercoat it as it may weaken the weld. Looks the same from 5 feet away however.
-One rear tire needs replacing as my alignment was bad for a month or two destroying one rear tire while the other one still has about 70-80% tread left.
-Front tires have probably 50% tread left
-Passenger side headlight trim tab is broken
I do all the work on my car myself. It runs perfect. Mileage on the car has been mostly highway miles its all life and has been taken care of and babied its entire life. A 120k mile car that has been taken care of is better than a 50k mile car that was beaten on, and that shows in the condition of my car.
Call/text me at 914 500 5221
I am asking 20,000 but I am negotiable and if you want we can work out a deal where I fix all the exterior issues prior to you buying the car. No tire kickers please do not waste my time.
This is an older pic showing curb rash, this is before I powdercoated the wheels.
The next two pics are from the previous owner as I do not have any interior pics right now however the interior still looks that good and I do have all those receipts.
Reactions: ChrisizzleM
Discussion Starter #2
bump, the price is negotiable..
nice, love the black RGRs.
thanks!
new asking price! 19,000
Just test drove a showroom condition 48k mile 03 m5. it was cosmetically showroom condition but mechanically it drove no where near as well as my car. I've driven close to 10 M5s and none of them felt as good as mine, it all depends how the car was taken care of throughout its life, and you can tell by the way it drives. Yes I am priced high, but how many other M5s have all the maintenance done, all the maintenance records as well, and not to be cocky but I guarantee you, you will not be able to find an M5 for 19k that drives like mine.
bump lets get this sold. willing to sell without the wheels.
You have the stock wheels?
No I do not, that would be up to the buyer to source stock wheels or with a deposit I can source stock wheels and put them on. All depends on the price the buyer and I agree on.
hmmm Selling a car that needs a tow truck and a forklift. :dunno:
Sounds like trying to condoms to a eunuch.
LOL (you forgot to say "sell" but I got it)
OP: I was confused about the bump and willing to sell the car w/o wheels, that's why I asked the question...
Reactions: AGM5
Sounds like trying to sell condoms to a eunuch.
haha well its up to the buyer, stock wheels can be sourced if the buyer prefers, is what I meant
My right rear tire blew, this is the one that had a very low tread life, as of next week, both rear tires will have at least 80% tread left and front tires have about 60% left. Rears are PSS, fronts are PS2s. Lets get this sold guys.
Brake rotors were also replaced as well as an oil change done. Alignment to be done next week as well as new brake hoses and a brake bleed. Keep in mind I perform all the work on my car, don't let any regular shop touch it. Only shop that has touched it under my ownership is Proformance Industries in New Rochelle, New York and they powdercoated the wheels, they are an exotics shop so I trust them to work on my car.
Oh, dear God, :eek: which oil did you use?
Edit double post
Discussion Starter #14
Discussion Starter #15
bump
Discussion Starter #17
Discussion Starter #18 (Edited)
repost
Discussion Starter #19
bump. price is obo
Discussion Starter #20
bump. getting an alignment and new fuel filter tomorrow. brake hoses are on order and once they come I will install them and bleed the brakes.
1 - 20 of 54 Posts
