2003 E39 M5 - LeMans Blue Metallic/Black Sport Interior
WBSDE93443CF92278
WBSDE93443CF92278
$23,500
I acquired this M5 in August of last year and have put under 5k miles on it. I have attached both the current CarFax and AutoCheck history reports as well as the BMW build sheet. I have a clean Tennessee title and there are no accidents reported on this M5.
Previous work completed within the last 10k miles prior to my ownership include cooling system refresh with new thermostat, water pump and aux fan switch and new brake rotors and pads.
Since I purchased it I have done the following within the past 500 miles:
Wheels refinished in shadow chrome by Prince Wheel.
New Continental Extreme Contact Sport tires.
Front control arms, thrust arms and tie rods replaced with Lemförder parts.
Rear control arms, guide rods and sway bar links replaced with Lemförder parts.
Four wheel alignment.
All shifter bushings replaced with OE parts. Shifter arm bushing/shifter bearing cup/shift lever bushing/selector rod joint.
Corteco engine mounts and Lemförder transmission mounts.
Mahle fuel filter.
All OE exterior rubber around front and rear windshield including front cowl pieces.
OE BMW windshield wipers.
OEM engine air filters and charcoal activated cabin air filters.
New rear ///M badge.
New OEM Stabilus trunk shocks.
Professional paint correction with CQuartz UK ceramic coating and with CQuartz DLux on the black plastic trim.
Euro sliding armrest with new leather. Original armrest included.
Engine oil changed with LiquiMoly 10W60 about 1,500 miles ago.
OE BMW timing chain tensioner.
New rubber mounts for the oil filter housing and power steering reservoir from McMaster Carr.
Transmission fluid change with Febi 75W80 oil.
Differential fluid change with LiquiMoly 75W140 oil.
Brake and slave cylinder fluid flush with ATE Typ 200 brake fluid.
Euro tune flashed along with NCSExpert coding changes.
With a large amount of maintenance done on this vehicle mechanically and cosmetically it will be a great M5 for someone to own and enjoy. It drives great and should continue to do so for many miles. I am located about twenty minutes north of Nashville, TN. If you have any questions feel free to contact me through this forum or you can send me a text at 615-819-4703.
