1 - 4 of 4 Posts
2002 BMW M5 Jet Black on Caramel
VIN: WBSDE93432CF91119
150k miles
$17,000
Located in Augusta, GA
It absolutely pains me to do this, but I am putting my most favorite car ever up for sale. My commute has recently drastically increased and I need a car I don’t mind destroying.
She is not a garage queen. She is a well maintained driver. Runs fantastic. No issues.
Modifications:
  • Dinan front strut bar
  • Dinan Stage 1 Suspension kit
  • F10 M5 shift knob
  • E60 shifter
  • black Ebay grills (OEM included)
  • cubby center arm rest (original included)
  • mufflers deleted
  • 9.5” square OEM Style 65’s recently powder coated - 3mm spacers front / 5mm rear (4 front wheels included)
  • weighted center caps
  • BavAuto ignition coils
Picture Album
Service records (from my ownership and the previous owner)
Date​
Mileage​
Service​
Location​
Cost​
02/19/2020​
147xxx​
Oil change and vehicle inspection​
Wile Motorsport​
$135.44​
07/14/2019​
144720​
Reseal door vapor barriers​
DIY​
Replace all four door lock motors​
DIY​
06/05/2018​
144148​
Brake rotors, pads, shoes, stainless lines​
South Shore Motor Works​
$2,662.13​
flush brake/clutch fluid​
Replace valve cover gaskets​
*all brake parts and plugs and​
replace exhaust brackets​
coils were customer supplied​
oil change​
replace fuel filter​
replace rear upper control arms​
4 wheel alignment​
Spark plugs and BavAuto coils​
09/23/2017​
141930​
Install e60 shift lever and F10 knob​
DIY​
09/09/2017​
141660​
New battery​
Batteries Plus Bulbs​
$299.61​
09/05/2017​
141430​
Driveshaft flex disc​
Vintage Sports and Restoration​
$1,283.60​
Rear diff mounts, reseal, change fluid​
power steering flush​
Oil change​
code out DRL​
08/22/2017​
140719​
Post Purchase Inspection​
$95.00​
Previous Owner Records
07/26/2016​
139935​
Dinan Stg1 Suspension and alignment​
Concord Motorsport​
$3,044.30​
11/18/2014​
137770​
Oil change​
Concord Motorsport​
$117.40​
05/13/2014​
135235​
Oil change​
Concord Motorsport​
$87.50​
04/23/2014​
135085​
Fuel pump replaced​
Concord Motorsport​
$375.00​
04/23/2014​
135060​
Replaced all four O2 sensors​
Concord Motorsport​
$238.00​
11/16/2013​
134890​
Replaced tranny fluid – Redline MTL​
$27.90​
10/26/2013​
134162​
Oil change​
$56.93​
01/25/2012​
113673​
Remove heads, clean secondary air ports​
Concord Motorsport​
$10,317.48​
Replace clutch, pilot, & release bearings​
Replace power steering lines to reservoir​
Replace air filters​
Replace cabin filters​
Replace PCV hoses​
Replace right front control arm​
Alignment​
Oil change​
Replace thermostat​
Replace air pump control valve​
Replace oil filter mounts​
Hoping to find her a good home. If I had the garage space I would keep her.
Let me know if you have any questions. Thank you.
Discussion Starter #2
Wow, I really thought there would be interest in this. I guess I will have to keep it then. So be it.
1 - 4 of 4 Posts
