1 - 11 of 11 Posts
After a great year of ownership, I am looking to sell my 2000 M5. This car has been great, one of my favorites so far that I have owned. Never thought I would sell but I want to get started on a project swap involving an s85 and could use the extra funds.
To the details...This is a 3 owner car. Well maintained and I have general records from the previous owner starting in 2010 at 25,000 miles. The last owner had the car until I purchased it at 90,000 miles. He had it all over the place starting in MD and ended up in SC where I purchased it. I would not hesitate to drive this car anywhere. I drive it everyday so mileage will go up slightly. Theres a few small dings on the driver door and the usual rock chips on the hood. The paint is in great condition other than those minor imperfections.
The car is completely stock other than a muffler delete and retrofitted headlights from a 2001 e39 (Lexus LS460 Projectors, 55w ballasts, 5k bulbs). At this time I also installed new lenses with the clear corners.
The back seat on the driver side needs repaired (see pics). The remainder of the rear bench seat is in great condition.
I was involved in an accident in January 2015, all work was done by BMW of Rockville and ALL parts were replaced with OEM parts. Nothing was "pulled, bondo, etc". They offer a lifetime warranty on their work as well. Other than the quarter panel, the rear bumper was replaced and at the time I had them replace the front bumper as well. I am very pleased with their work.
Details:
2000 m5
Oxford Green
104,000 miles
Extended English Green Napa Leather
e60 shifter / UUC DSSR
2001 Headlights
Clean Title in hand
Records (have all recorded in a book for next owner):
New Battery -- 1/30/13 -- 68,257 miles
New Brake Pads -- 5/12/13 -- 73,980 miles
New Tires -- 6/28/13 -- 78,013 miles
OEM Clutch -- 8/30/14 -- 90,000 miles
OEM MAF (2) -- 9/18/14 -- 91,000 miles
OEM Exhaust CPS (2) -- 9/23/14 -- 91,300 miles
OEM Intake CPS (2) -- 9/23/14 -- 91,300 miles
OEM Fuel Filter -- 9/23/14 -- 91,300 miles
OEM Timing Chain Tensioner (lower) -- 10/11/14 -- 92,400 miles
OEM Lower Oil Pan Gasket -- 12/7/14 -- 94,575 miles
OEM Oil Sep. Hoses (Top and Bottom) -- 12/7/14 -- 94,575 miles
Thrust Arms -- 12/20/14 -- 95,200 miles
Muffler Delete -- 3/25/15 -- 95,600 miles
Spark Plugs -- 4/1/15 -- 96,000 miles
Valve Cover Gasket (Driver) -- 4/1/15 -- 96,000 miles
Diff Fluid Change Royal Purple 75/140 -- 7/6/15 -- 99,500 miles
Pre Cat O2 Sensors -- 7/6/15 -- 99,500 miles
Brake Fluid Flush -- 7/6/15 -- 99,500 miles
OEM Front Crankshaft Oil Seal -- 8/21/15 -- 102,000 miles
Power Steering Hose Part #32412228868 -- 8/21/15 -- 102,000 miles
Power Steering Flush -- 8/21/15 -- 102,000 miles
OEM Fuel Pump Relay -- 9/11/15 -- 102,200 miles
All that said, I'm motivated to sell the car and I believe it is priced fair considering all of the above. Im aware the interior is a downfall, but thanks to Clemster you can get a full interior swap for a great package price if you want!
PRICE: $12,000 OBO
So sad Mike :frown - but S85 project sounds :devil
Was the VANOS ever rebuilt? And I'm assuming you did the guides when the tensioner was replaced? Beautiful Car!!
No records of any vanos work and I Havnt done them. I've had zero signs that they need done. If I were to keep the m5 I was going to do the solenoid o rings only, just to be sure they are not clogged with the mesh screen.
I apologize should have been more clear the tensioner was the lower "external" one. So no to the guides. To my knowledge the motor has never been opened up further than a valve cover gaslet job. But same as vanos, I have no signs of issues.
Thanks!
Reactions: nickkhann
I am also interested in this car and local, about 15-20 mins away.
Would like to come see the car. I am unable to PM. If someone could PM the OP I would appreciate it.
OP can reach me at seven Seven three - Seven four four - 9696
Discussion Starter · #10 ·
I apologize to all who have reached out via this thread. Only received notifications of PM.
M5 has SOLD
1 - 11 of 11 Posts
